New sonoff zigbee temp sensor SNZB-02D
Did all that. Right next to hub. Many times. No go.
Reset app, reset hub…
It doesn’t pair as a thing either? Let’s see if you’re at the hub’s memory limit
It should pair as a thing and you can see the real fingerprints, it may be different than what it thinks it is.
No, not even a thing. Doesn’t detect anything.
Going to smarthings and hub it says
driverMemoryLimitStatus
Ok
Let me know what I can to debug.
Thanks.
If the green light on your hub is blinking and nothing is found, it’s most likely that the device is not in pairing mode.
Have you tried a different device that is easy to put into pairing mode to rule out any issues with the hub?
Unlikely, but as a last resort you could try a fresh battery
Yes. Double checked blinking green led on hub.
Wireless indicator on the sensor LCD screen blinks for about 30 seconds then gives up. So pretty sure it’s in pairing mode …
Will try another device and let u know.
I was able to add an old ecosmart ZigBee bulb to hub no problem.
So it’s not the hub. So it’s either hub software update broke it or a bad sensor if everyone can add except me.
Does anyone with latest firmware able to try to delete and re-add if it’s not too hard to do so?
Thanks,
Anyone knows when is the next hub update or how often? I don’t want to lose my window to return the sonoff sensor if it’s not going to work.
Did you try a new battery in the sensor ?
Yes. No go. Samer result.
I tested today in my remote location.
I deleted SNZB-02D and then paired it again without any problem.
Pairing was successful with the first Scan nearby attempt.
During pairing, SNZB-02D was 20 cm away from the hub.
My hub is SmartThings V3 and firmware is 54.10.
SNZB-02D firmware in AWA is 00001009.
Thanks a lot for trying. The only difference now is that your hub is v3. Will give it another shot.
Note: i wanted to get another sonoff device to test with and noticed all of a sudden most sonoff sensors disappeared from Amazon… weird…
Thx
I am using my Frame TV (QN55LS03D) as a hub, and cannot link the Sonoff SNZB-02P. Sensor us not detected! Any help greatly appreciated!
Install this driver to your hub
and install SNZB-02P again
Are you certain your TV supports zigbee? Are you using a zigbee/thread dongle.
Specs say that Zigbee/Thread are built-in.
Hey guys, I just got the SNZB-02D temp sensor and tried to connect it to my ST hub (used QR scan) I got the following error “This device isn’t supported in your Samsung account’s country or region.”
I am located in the USA.
I ordered the parts from AliExpress.
ST Hub v3
How did you guys get it to work?! What am I missing?
Try add device scan nearby when sensor is in pairing mode.
I’m an idiot, I wasn’t holding the button long enough.
I had tried the scan nearby but got nothing on that. I just held the button for longer.
Your message did help because it let me know that I should be able to connect to it. I was thinking maybe holding it for a very long time will reset the device. Also pulled battery.
But just had to hold it for longer than the 5 seconds.
Connected now!!!
Thank you Very Much!!!
Sonoff has released new versions of the SNZB-02D sensors.
Zigbee LCD Smart Thermometer (Probe Version) | SNZB-02LD - SONOFF Official
Zigbee LCD Smart Temperature Humidity Sensor | SNZB-02WD - SONOFF Official
