Hello,
I have an question, about new API , I think that I don’t understand new model Smart App, totally. I created SmartApp on base of documentation but if I should create all handle functions by myself (despite of exsisting API) ? And if response is yes, in what way I should create handlePIng function, because I can’t see information on this subject in documentation.
indent preformatted text by 4 spaces
> Import the necessary libraries/declare the necessary objects:
// Basic Server:
//framework
var express = require("express");
// Body-Parser
var bodyParser = require("body-parser");
// Request
var request = require('request');
// Http
var http = require('http');
//baseUrl
var baseUrl = "https;//api.smartthing.com";
// Https
var https = require('https');
// Files
var fs = require('fs');
// Http-signature
var httpSignature = require('http-signature');
//Key and cert created by openssl
var options = {
key: fs.readFileSync('data/agent2-key.pem'),
cert: fs.readFileSync('data/agent2-cert.cert')
//create a service
var app = express();
app.use(bodyParser.json());
//app.use(myParser.urlencoded({extended : true}));
app.post('/smartthings', function (req, response) {
// We don't yet have the public key during PING (when the app is created),
// so no need to verify the signature. All other requests are verified.
if (req.body && req.body.lifecycle === "PING" || signatureIsVerified(req)) {
handleRequest(req, response);
} else {
response.status(401).send("Forbidden");
function signatureIsVerified(req) {
try {
let parsed = httpSignature.parseRequest(req);
if (!httpSignature.verifySignature(parsed, publicKey)) {
console.log('forbidden - failed verifySignature');
return false;
} catch (error) {
console.error(error);
return false;
return true;
function handleRequest(req, response, error) {
// handle all lifecycles from SmartThings
let evt = req.body;
let lifecycle = evt.lifecycle;
let res = null;
switch(lifecycle) {
case 'PING':
res = handlePing(evt.pingData.challenge);
resp.json({statusCode: 200, pingData: {challenge:res}});
break;
case 'CONFIGURE':
res = handleConfig(evt.configurationData);
resp.json({statusCode: 200, configurationData: res});
break;
case 'INSTALL':
handleInstall(evt.installData.installedApp, evt.installData.authToken);
resp.json({statusCode: 200, installData: {}});
break;
case 'UPDATE':
handleUpdate(evt.updateData.installedApp, evt.authToken);
resp.json({statusCode: 200, updateData: {}});
break;
// handle other lifecycles...
case 'EVENT':
//???????? handleEvent write
handleEvent(evt.eventData.installedApp, evt.authToken);
resp.json({statusCode: 200, eventData:{}});
break;
case 'OAUTH_CALLBACK':
handleoAuthCallback(evt.oAuthCallbackData.installedAppId , evt.oAuthCallbackData.urlPath);
resp.json({statusCode: 200, oAuthCallbackData:{}});
break;
case 'UNINSTALL':
handleUninstall(evt.uninstallData.installedApp, evt.uninstallData.authToken);
resp.json({statusCode: 200, uninstallData:{}});
default:
console.log(`lifecycle ${lifecycle} not supported`);
function initializing(){
console.log("Https server works");
//Start the server and make it listen for connections on port 8080
//http.createServer(app).listen(3000 , listening);
https.createServer(options, initializing).listen(8080);
Best regards
