Diegocampy:
Data * endpointId: 02
manufacturer: frient A/S
model: SPLZB-131
zigbeeNodeType: ROUTER
Raw Description 02 0104 0051 10 09 0000 0702 0003 0009 0B04 0006 0004 0005 0002 05 0000 0019 000A 0003 0406
This model is in the stock beta Zigbee Switch driver.
#frient A/S
- id: "frient A/S/SPLZB-131"
deviceLabel: "frient Outlet"
model: SPLZB-131
deviceProfileName: switch-power-energy
Do you want I add it to the Zigbee Switch Power Mc driver for some reason?
Diegocampy
(Diego Campy)
June 4, 2022, 5:27pm
#142
Sorry, I know or Iβm wrong maybe, I looked for it and it was added via de ice handler and not edge. Maybe the standard zigbee drive I have to add it first, I had not understood. But this measures consumption, we are sure that the drive Does it detect power consumption?
The assigned profile is switch-power-energy and it must be works fine with power and energy.
You have to install zigbee switch driver from smartthings Beta Channel and device will be paired with this driver
Diegocampy
(Diego Campy)
June 4, 2022, 5:47pm
#144
I apologize for my little knowledge, and thank you for your always very kindness in helping.
You donβt have to apologize, here we all learn from each other
Diegocampy
(Diego Campy)
June 4, 2022, 6:33pm
#146
Thanks, now I just have to find the link to see Samsung drives and try to install it. I did a thousand searches on the forum, but I canβt find anything, itβs not very intuitive.
@Diegocampy
Build a smart home to support all your big moments. With SmartThings, your home becomes a connected space that makes your life simpler, safer, and more entertaining.
Surely you already have your hub registered in the channel and from the app-hub you have access to the drivers of that channel
This is the link to smartthings GitHub beta drivers
hi,
Published new version of Zigbee Multi Switch Mc to fix problem with button status in new android app version
I have created 3 new VIDs with the alternatives and everything has been updated correctly.
Iβve published new vwersion it on the shared channel
βββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β Zigbee Multi Switch Mc β
β Version β 2022-06-21T11:22:45.884747294 β
βββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
[Screenshot_20220621-132613]
[Screenshot_20220621-132553]
[Screenshot_20220621-132522]
[Screenshot_20220621-132449]
dusanhauko
(Dusanhauko)
June 29, 2022, 7:08pm
#149
makskr
(Maxim)
July 1, 2022, 3:36am
#150
HI @Mariano_Colmenarejo
Could create the device driver, please?
application: 40
endpointId: 01
firmwareFullVersion: 00000040
firmwareImageType: 54179
firmwareManufacturerCode: 4417
manufacturer: _TZB210_tmi0rihb
model: TS0505B
Raw Description:01 0104 010D 01 09 0003 0004 0005 0006 1000 0008 0300 EF00 0000 02 0019 000A
makskr:
application: 40
endpointId: 01
model: TS0505B
Hello @makskr
It could work, there are other similar ones in the driver.
I wonβt be able to do it until August, Iβve already set a reminder.
At the moment you can use this DTH using the IDE.
Hello @dusanhauko
I have not added any TS0601 model, that I remember.
Without seeing the fingerprints, the clusters it uses, I wouldnβt know if can works. if only use the EF00 surely not.
