│ Name │ Zigbee Multi Switch Mc │
│ Version │ 2022-05-25T11:17:36.237860847 │
I remember that the drive should update itself after a few hours … so far my hub hasn’t updated the hub. Could it be my problem? I wonder why even with Tasmota EDGE I am having problems after a drive update.
It’s not your problem
It seems that they have not been published well in the channel, I am sure that I published them yesterday, but they were not published.
I have published them again and now they are on the channel
│ Zigbee Switch Mc │ 580a4441-7d16-437e-8cdc-97c03f59e2df │ 2022-05-24T20:02:40.11474948 │
│ Zigbee Switch Power Mc │ f732925a-9ae3-462a-9641-f03f474c661e │ 2022-05-24T21:14:49.802706414 │
│ Zigbee Multi Switch Mc │ 91a22a50-31a2-4177-9999-8ed3770bfee6 │ 2022-05-25T11:17:36.237860847 │
By adding the Last Hop capability Signal Metrics is emitted every 5 minutes when the periodic status message is received.
If there is any small change, the new event will also be seen in the app history.
To decrease the number of not necessary events in the history:
I have added a preference to make Visible or Not visible these events in the App History
By default it is set to Not Visible, if you need to troubleshoot the signal, it can be set to Visible to analyze the changes in the metrics over a given period
│ Version │ 2022-05-27T20:13:16.607739055 │
(NEW RELEASE)Version 5 update for the Edge Beta Driver: Zigbee Switch Power Mc
Improvements:
Added capability for Device Last Hop Metrics Signal, LQI and RSSI. Same as Zigbee Multi Switch Mc
As it has given me some problem when updating it overwriting the previous version, it may be that due to the new custom capability, then I will not do an automatic update.
To facilitate the update, I am going to change driver version 4 to the name Zigbee Switch Power Mc-(OLD).
I will publish the new version 5 with the original name Zigbee Switch Power Mc
In this way, your driver installed will renamed with (OLD), indicating that there is a new version available and you can install the new version with a driver change whenever you want.
Driver version:
│ Name │ Zigbee Switch Power Mc │
│ Version │ 2022-05-30T19:22:05.17791839 │
Hi @Helder_Rodrigues
I don’t know if I understand you well
Does it pair with the zigbee multi switch Mc?
Do you want to change the name of switch2?
If this is true, you cannot rename components other than main (switch1) in this driver
(NEW RELEASE)Version 6.5 for the Edge Beta Driver: Zigbee Switc Mc
Improvements:
As request of @BlackRose67, I added new profile Switch-battery
As it has new custom capability and profile and avoid possible inconveniences, then I will not do an automatic update.
To facilitate the update, I am going to change driver version 6 to the name Zigbee Switch Mc-(OLD).
I will publish the new version 6.5 with the original name Zigbee Switch Mc
@BlackRose67 you do not need update to new version, it will be done automatically for you
Fantastic, I updated my devices one by one and I had a thought: is it possible to know how many devices use a certain drive? I only have 5 devices with this drive, but they will become 21 after updating my home switches that still use DH to edge. It will be a hassle ggFantastic, I updated my devices one by one and I had a thought: is it possible to know how many devices use a certain drive? I only have 5 devices with this drive, but they will become 21 after updating my home switches that still use DH to edge. It will be a hassle to update new drives every time
Hi @Diegocampy
The manual update will only be used when there are changes in the new driver that may compromise the proper functioning of the device when it is initialized with the new driver version.
Once we get out of the Beta phase it should be less necessary even hopefully totally unnecessary.
In the meantime, I will do so when I have doubts that the changes could create problems for users at times that Murphy carefully chooses to…
