I have subscribed to the channel and installed Zigbee Multi Switch and Child Mc.
I can’t seem to get the switch to work - it will connect to my smartthings hub, but the device page is unresponsive, and doesn’t show “driver” in the settings menu - no change from before I installed the driver.
I have deleted, reset and re-added the switch to smartthings but to no avail.
Is there a certain order I should be doing things in terms of installing drivers, deleting devices etc?
Thanks so much for any advice you can give.
Thank you. I have just done a fresh reset and verified it is the same device as on list. But still having same issue… After I remove the device, SmartThings seems to just pick up the same device again once I reset the switch (even places it back in the same room)
Here is the info from API+. Looks like it is still using DTH. Is there a way to force it not to?
are you sure the fingerprint matches each field 100%?
The name seems off?
You could try adding the zigbee thing driver to get mroe detailed stuff for marino to fingerprint.
How GOD to add an Tuya zigbee 1 button mini switch? It’s called Woox R7053. Do i need an Tuya hub also or i can add directly to Aeotec hub v3?
If only with Aeotec hub, how to do it?
Hi mr. Mariano. Tnx for support!
That device is ZigBee 3.0. Since i am new, can you help me and redirect where and how to find fingerprints, manufacturer and model for Woox R7053?
