Thank you. I have just done a fresh reset and verified it is the same device as on list. But still having same issue… After I remove the device, SmartThings seems to just pick up the same device again once I reset the switch (even places it back in the same room)
Here is the info from API+. Looks like it is still using DTH. Is there a way to force it not to?
are you sure the fingerprint matches each field 100%?
The name seems off?
You could try adding the zigbee thing driver to get mroe detailed stuff for marino to fingerprint.
Thanks @Mariano_Colmenarejo
Perfect! That did the trick!
Very much appreciate your hard work.
Also thank you @kortex for your help.
How GOD to add an Tuya zigbee 1 button mini switch? It’s called Woox R7053. Do i need an Tuya hub also or i can add directly to Aeotec hub v3?
If only with Aeotec hub, how to do it?
Thank you!
If it’s wifi it doesn’t work with hub v3.
If it is zigbee 3.0 it could work. It would be necessary to know the fingerprints, manufacturer and model
Hi mr. Mariano. Tnx for support!
That device is ZigBee 3.0. Since i am new, can you help me and redirect where and how to find fingerprints, manufacturer and model for Woox R7053?
You can install the Zigbee Thing Mc driver on your hub from my channel.
add the device with the app to see if it pairs with the controller and it will show you all the information
It’s a Sengled smart light switch
e39-g8c
But it’s a button with battery, right?
If so, it doesn’t work with my driver.
Maybe @erickv or @ygerlovin can add it to their drivers
Hi @Mariano_Colmenarejo ,
I’m using your driver with a Sonoff mini switch but the power measurement show 0. How can I check if this unit support this capability with the CLI?
Ooooh - sorry. I missed that. Thanks for the reference to the other devs.
I see, so are the capabilities shown with the devices:capability-status cli command dependent on the used edge driver?
Depend of the profile assigned in the driver
I have an osram plug here and I’m not sure if this one should measure the power or not, how can I be sure of it?
If is paired with a DTH then can see the fingerprints and clusters in IDE device data
You Could install driver Zigbee Thing Mc from my channel and try to pair with it. This driver shows all device information fingerprints and clusters supported
