Thanks for making the change so quickly.
Here is the complete log for paring the device with the updated driver. I noticed there is an error at the end. After pairing the switch seem to be operational, but the log also show the same error. See second part of log. Also, when i open the device card on smartthings app. I get the error “Couldn’t get device status”
------ Device pairing log —
2022-11-21T23:31:05.420019885+00:00 WARN Zigbee Switch Mc Unexpected filesystem lookup for capability legendabsolute60149.driverVersion1
2022-11-21T23:31:05.450329135+00:00 TRACE Zigbee Switch Mc Setup driver Zigbee_Switch with lifecycle handlers:
DeviceLifecycleDispatcher: Zigbee_Switch
default_handlers:
init:
removed:
doConfigure:
infoChanged:
driverSwitched:
child_dispatchers:
2022-11-21T23:31:05.454395344+00:00 TRACE Zigbee Switch Mc Setup driver Zigbee_Switch with Capability handlers:
CapabilityCommandDispatcher: Zigbee_Switch
default_handlers:
legendabsolute60149.energyReset1:
setEnergyReset
switch:
off
on
legendabsolute60149.randomOnOff2:
setRandomOnOff
legendabsolute60149.getGroups:
setGetGroups
energyMeter:
resetEnergyMeter
refresh:
refresh
child_dispatchers:
2022-11-21T23:31:05.458329219+00:00 TRACE Zigbee Switch Mc Setup driver Zigbee_Switch with Zigbee handlers:
ZigbeeMessageDispatcher: Zigbee_Switch
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryVoltage
ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
global:
ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
cluster:
ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
zdo:
child_dispatchers:
2022-11-21T23:31:05.480494927+00:00 TRACE Zigbee Switch Mc Zigbee Device: c9ddf88d-d9f0-4683-9377-fcf086c512f4
Manufacturer: Quirky Model: Smart Switch
[1]: Basic, Identify, 0xFC20 [2]: Basic, Identify, OnOff, Scenes, Groups
2022-11-21T23:31:05.484992344+00:00 DEBUG Zigbee Switch Mc driver device thread event handled
2022-11-21T23:31:05.517897219+00:00 TRACE Zigbee Switch Mc Received event with handler _resync
2022-11-21T23:31:05.521054677+00:00 TRACE Zigbee Switch Mc Received event with handler environment_info
2022-11-21T23:31:05.528554635+00:00 TRACE Zigbee Switch Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-11-21T23:31:05.532230927+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> emitting event: {“attribute_id”:“randomOnOff”,“capability_id”:“legendabsolute60149.randomOnOff2”,“component_id”:“main”,“state”:{“value”:“Inactive”}}
2022-11-21T23:31:05.543638760+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> emitting event: {“attribute_id”:“randomNext”,“capability_id”:“legendabsolute60149.randomNextStep2”,“component_id”:“main”,“state”:{“value”:“Inactive”}}
2022-11-21T23:31:05.559181719+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> emitting event: {“attribute_id”:“energyReset”,“capability_id”:“legendabsolute60149.energyReset1”,“component_id”:“main”,“state”:{“value”:“Last: 0.000 kWh (11/21/2022)”}}
2022-11-21T23:31:05.569857094+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:05.573310427+00:00 TRACE Zigbee Switch Mc Received event with handler environment_info
2022-11-21T23:31:05.576860594+00:00 DEBUG Zigbee Switch Mc Z-Wave hub node ID environment changed.
2022-11-21T23:31:05.584749844+00:00 TRACE Zigbee Switch Mc Received event with handler device_lifecycle
2022-11-21T23:31:05.588147469+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received lifecycle event: added
2022-11-21T23:31:05.592697135+00:00 TRACE Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received unhandled lifecycle event: added
2022-11-21T23:31:05.595890635+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:05.599388427+00:00 TRACE Zigbee Switch Mc Received event with handler device_lifecycle
2022-11-21T23:31:05.602898052+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received lifecycle event: doConfigure
2022-11-21T23:31:05.608313969+00:00 TRACE Zigbee Switch Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-11-21T23:31:05.614523677+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC40B, dest_endpoint: 0x02, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 7C25E4000010A97E, src_endpoint: 0x02, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 24FD5B0000032AF9, dest_endpoint: 0x01 > > >
2022-11-21T23:31:05.625060594+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC40B, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-11-21T23:31:05.640570469+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:05.649745260+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:05.790251927+00:00 TRACE Zigbee Switch Mc Received event with handler zigbee
2022-11-21T23:31:05.795989219+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -56, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x7B >, < BindRequestResponse || status: 0x00 > > >
2022-11-21T23:31:05.805000469+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:05.967424677+00:00 TRACE Zigbee Switch Mc Received event with handler device_lifecycle
2022-11-21T23:31:05.975079344+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received lifecycle event: infoChanged
2022-11-21T23:31:05.980411094+00:00 TRACE Zigbee Switch Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-11-21T23:31:05.985120094+00:00 PRINT Zigbee Switch Mc << do_Prefrences >>
2022-11-21T23:31:05.988575094+00:00 PRINT Zigbee Switch Mc << Preference changed name: signalMetricsVisibles old value: nil new value: No
2022-11-21T23:31:06.017580927+00:00 PRINT Zigbee Switch Mc << Preference changed name: changeProfile old value: nil new value: Switch
2022-11-21T23:31:06.024992052+00:00 PRINT Zigbee Switch Mc << Preference changed name: randomMin old value: nil new value: 1.0
2022-11-21T23:31:06.028350677+00:00 PRINT Zigbee Switch Mc << Preference changed name: logDebugPrint old value: nil new value: false
2022-11-21T23:31:06.031868594+00:00 PRINT Zigbee Switch Mc << Preference changed name: groupAdd old value: nil new value: 0.0
2022-11-21T23:31:06.036160344+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC40B, dest_endpoint: 0x02, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2022-11-21T23:31:06.050963177+00:00 PRINT Zigbee Switch Mc << Preference changed name: powerTimer old value: nil new value: 5.0
2022-11-21T23:31:06.054172760+00:00 PRINT Zigbee Switch Mc << Preference changed name: version old value: nil new value:
2022-11-21T23:31:06.059288802+00:00 PRINT Zigbee Switch Mc << Preference changed name: localTimeOffset old value: nil new value: 0
2022-11-21T23:31:06.065340635+00:00 PRINT Zigbee Switch Mc << Preference changed name: loadPower old value: nil new value: 0
2022-11-21T23:31:06.076643135+00:00 PRINT Zigbee Switch Mc << Preference changed name: randomMax old value: nil new value: 10.0
2022-11-21T23:31:06.079952344+00:00 PRINT Zigbee Switch Mc << Preference changed name: offTime old value: nil new value: 10
2022-11-21T23:31:06.083550510+00:00 PRINT Zigbee Switch Mc << Preference changed name: onTime old value: nil new value: 10
2022-11-21T23:31:06.087223594+00:00 PRINT Zigbee Switch Mc << Preference changed name: restoreState old value: nil new value: 255
2022-11-21T23:31:06.090463510+00:00 PRINT Zigbee Switch Mc <<< Write restore state >>>
2022-11-21T23:31:06.095035760+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC40B, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x4003, DataType: Enum8, data: 0xFF > > > >
2022-11-21T23:31:06.107080427+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC40B, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x8002, DataType: Enum8, data: 0x02 > > > >
2022-11-21T23:31:06.118682344+00:00 PRINT Zigbee Switch Mc << Preference changed name: groupRemove old value: nil new value: 1.0
2022-11-21T23:31:06.122149052+00:00 PRINT Zigbee Switch Mc Remove Groups >>>>>>>>>>>>>>>>>
2022-11-21T23:31:06.135979635+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC40B, dest_endpoint: 0x02, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x03 >, < RemoveGroup || group_id: 0x0001 > > >
2022-11-21T23:31:06.144594427+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xC40B, dest_endpoint: 0x02, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2022-11-21T23:31:06.151684010+00:00 PRINT Zigbee Switch Mc Device ID <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)>
2022-11-21T23:31:06.154832219+00:00 PRINT Zigbee Switch Mc Manufacturer >>> Quirky Manufacturer_Len >>> 6
2022-11-21T23:31:06.167567385+00:00 PRINT Zigbee Switch Mc Model >>> Smart Switch Model_len >>> 12
2022-11-21T23:31:06.170590219+00:00 PRINT Zigbee Switch Mc <<<<< Firmware Version >>>>>
2022-11-21T23:31:06.173866802+00:00 PRINT Zigbee Switch Mc Memory >>>>>>> 1144.3369140625 Kbytes
2022-11-21T23:31:06.177252094+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:06.189320094+00:00 TRACE Zigbee Switch Mc Received event with handler zigbee
2022-11-21T23:31:06.195984844+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -56, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x7D, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || ZclStatus: SUCCESS > > >
2022-11-21T23:31:06.237470344+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:06.243952552+00:00 TRACE Zigbee Switch Mc Received event with handler zigbee
2022-11-21T23:31:06.248836635+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xFF, rssi: -58, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x7E, ZCLCommandId: 0x02 >, < GetGroupMembershipResponse || capacity: 0x08, group_list_length: 0x00 > > >
2022-11-21T23:31:06.266028010+00:00 TRACE Zigbee Switch Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-21T23:31:06.307525135+00:00 INFO Zigbee Switch Mc Executing ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
2022-11-21T23:31:06.311587177+00:00 PRINT Zigbee Switch Mc group_list >>>>>> {}
2022-11-21T23:31:06.315005177+00:00 PRINT Zigbee Switch Mc All Deleted
2022-11-21T23:31:06.326684677+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> emitting event: {“attribute_id”:“getGroups”,“capability_id”:“legendabsolute60149.getGroups”,“component_id”:“main”,“state”:{“value”:“All Deleted”}}
2022-11-21T23:31:06.337769969+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:06.346041344+00:00 TRACE Zigbee Switch Mc Received event with handler zigbee
2022-11-21T23:31:06.353857969+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -57, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x7F, ZCLCommandId: 0x04 >, < WriteAttributeReponse || < WriteAttributeResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, AttributeId: 0x4003 > > > >
2022-11-21T23:31:06.363515469+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:06.366981969+00:00 TRACE Zigbee Switch Mc Received event with handler zigbee
2022-11-21T23:31:06.372189802+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -57, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x00, ZCLCommandId: 0x04 >, < WriteAttributeReponse || < WriteAttributeResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, AttributeId: 0x8002 > > > >
2022-11-21T23:31:06.381670219+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:06.385008760+00:00 TRACE Zigbee Switch Mc Received event with handler zigbee
2022-11-21T23:31:06.391869594+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xFF, rssi: -56, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x01, ZCLCommandId: 0x03 >, < RemoveGroupResponse || status: 0x8B, group_id: 0x0001 > > >
2022-11-21T23:31:06.431956510+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:06.499419052+00:00 TRACE Zigbee Switch Mc Received event with handler zigbee
2022-11-21T23:31:06.504121844+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xFF, rssi: -58, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x02, ZCLCommandId: 0x02 >, < GetGroupMembershipResponse || capacity: 0x08, group_list_length: 0x00 > > >
2022-11-21T23:31:06.512806052+00:00 TRACE Zigbee Switch Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-21T23:31:06.515952302+00:00 INFO Zigbee Switch Mc Executing ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
2022-11-21T23:31:06.519454344+00:00 PRINT Zigbee Switch Mc group_list >>>>>> {}
2022-11-21T23:31:06.523080510+00:00 PRINT Zigbee Switch Mc All Deleted
2022-11-21T23:31:06.526627510+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> emitting event: {“attribute_id”:“getGroups”,“capability_id”:“legendabsolute60149.getGroups”,“component_id”:“main”,“state”:{“value”:“All Deleted”}}
2022-11-21T23:31:06.536710260+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:31:07.016055761+00:00 TRACE Zigbee Switch Mc Received event with handler zigbee
2022-11-21T23:31:07.060766344+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -57, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x01, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-11-21T23:31:07.112678052+00:00 TRACE Zigbee Switch Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-21T23:31:07.164250302+00:00 INFO Zigbee Switch Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-11-21T23:31:07.183644552+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2022/11/21 Time: 23:31
DNI: 0xC40B LQI: 255 RSSI: -57dbm
”},“visibility”:{“displayed”:false}}
2022-11-21T23:31:07.225862177+00:00 PRINT Zigbee Switch Mc <<<<< device.fingerprinted_endpoint_id >>>>>> 1
2022-11-21T23:31:07.231286969+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-11-21T23:31:07.250327386+00:00 PRINT Zigbee Switch Mc <<<<< device.fingerprinted_endpoint_id >>>>>> 1
2022-11-21T23:31:07.254280094+00:00 ERROR Zigbee Switch Mc Smart Switch thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)>:
arg1: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -57, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x01, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
[string “st/device.lua”]:121: attempt to index a nil value (local ‘component’)
2022-11-21T23:31:35.476225268+00:00 DEBUG Zigbee Switch Mc driver device thread event handled
-------- Device control from smartthings app log ------
2022-11-21T23:36:50.185371707+00:00 TRACE Zigbee Switch Mc Received event with handler capability
2022-11-21T23:36:50.190797207+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received command: {“args”:{},“capability”:“switch”,“command”:“off”,“component”:“main”,“positional_args”:{}}
2022-11-21T23:36:50.194080749+00:00 TRACE Zigbee Switch Mc Found CapabilityCommandDispatcher handler in Zigbee_Switch
2022-11-21T23:36:50.197387791+00:00 PRINT Zigbee Switch Mc <<<<< device.fingerprinted_endpoint_id >>>>>> 1
2022-11-21T23:36:50.217492749+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
2022-11-21T23:36:50.299888874+00:00 TRACE Zigbee Switch Mc Received event with handler zigbee
2022-11-21T23:36:50.304757124+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -59, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x04, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-11-21T23:36:50.315441541+00:00 TRACE Zigbee Switch Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-21T23:36:50.318784791+00:00 INFO Zigbee Switch Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-11-21T23:36:50.329540874+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2022/11/21 Time: 23:36
DNI: 0xC40B LQI: 255 RSSI: -59dbm
2022-11-21T23:36:50.352272791+00:00 PRINT Zigbee Switch Mc <<<<< device.fingerprinted_endpoint_id >>>>>> 1
2022-11-21T23:36:50.356240374+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-11-21T23:36:50.369163624+00:00 PRINT Zigbee Switch Mc <<<<< device.fingerprinted_endpoint_id >>>>>> 1
2022-11-21T23:36:50.374254749+00:00 ERROR Zigbee Switch Mc Smart Switch thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)>:
arg1: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -59, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x04, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-11-21T23:36:50.379273624+00:00 TRACE Zigbee Switch Mc Received event with handler zigbee
2022-11-21T23:36:50.384215291+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xC40B, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -60, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x07, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2022-11-21T23:36:50.393883374+00:00 TRACE Zigbee Switch Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-21T23:36:50.397451166+00:00 INFO Zigbee Switch Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2022-11-21T23:36:50.401560707+00:00 PRINT Zigbee Switch Mc <<<<< device.fingerprinted_endpoint_id >>>>>> 1
2022-11-21T23:36:50.405072541+00:00 INFO Zigbee Switch Mc <ZigbeeDevice: c9ddf88d-d9f0-4683-9377-fcf086c512f4 [0xC40B] (Smart Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-11-21T23:36:50.414459791+00:00 DEBUG Zigbee Switch Mc Smart Switch device thread event handled
