(NEW RELEASE) Version 5 of the Edge Beta Driver: Zigbee Switch Mc
Is this driver in your channel/? smartthings zigbee switch stock beta driver.
See instruction here
Preview | SmartThings-managed Edge Device Drivers - Devices & Integrations - SmartThings Community
Thanks a lot. I am glad you understand that I’m only new to this and just slowly getting on with things how to find install and set up :stuck_out_tongue:
Hi. Found 3 phase variant.
According to: [Device Support Request] 3Phase Hiking Tomzn Power Meter DTS238-7 Zigbee (analog of Single Phase DDS238-2 Zigbee) Β· Issue #1298 Β· zigpy/zha-device-handlers Β· GitHub
It uses Ef00 cluster. So no luck with your drivers…
Correct, it does not work with my driver
@N_Mendes, @Udah1, @dotan_shai, @flotueur
Added these devices to this driver version
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ Name        β”‚ Zigbee Multi Switch Mc               β”‚
β”‚ Version     β”‚ 2022-08-05T12:00:18.149650245        β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
  - id: "Zemismart/_TZ3000_zmbedyhc"
    deviceLabel: Zemismart three Switch
    manufacturer: _TZ3000_zmbedyhc
    model: TS0003
    deviceProfileName: three-switch
- id: "Zemismart/_TZ3000_sieosxue"
    deviceLabel: Three Switch
    manufacturer: _TZ3000_sieosxue
    model: TS0003
 - id: "Zemismart/_TZ3000_pc0qmva4"
    deviceLabel: Two Switch
    manufacturer: _TZ3000_pc0qmva4
    model: TS0002
    deviceProfileName: two-switch
 - id: "Lonsonho/_TZ3000_fisb3ajo"
    manufacturer: _TZ3000_fisb3ajo
    model: TS0002
 - id: "LIDL/_TZ3000_vzopcetz"
    deviceLabel: Lidl MultiPlug
    manufacturer: _TZ3000_vzopcetz
    model: TS011F
    deviceProfileName: three-outlet
Any chance of adding this?
Smartenit ZBMLC30
Data * zigbeeNodeType: ROUTER
  • firmwareManufacturerCode: 4213
  • firmwareFullVersion: 44050000
  • application: 44
  • endpointId: 01
  • firmwareImageType: 25
  • manufacturer: Compacta International, Ltd
  • model: ZBMLC30
    Raw Description 01 0104 0002 02 06 0000 0003 0006 0004 0005 0008 01 0019
Original Smartenit DTH
Would be great if so, otherwise thanks again for all your work.
Could you tell me what device it is?
The clusters you send me and those of the DTH you use do not match.
According to the DTH it is a Metering Dual Load Controller:
fingerprint profileId: "0104", inClusters: "0000,0003,0004,0005,0006,0702", outClusters: "0019", model: "ZBMLC30", deviceJoinName: "Smartenit Metering Dual Load Controller"
and according to the clusters sent, it does not have clusters.simple_metering (0702) and if it has level (0008)
It’s a 110v/220v dual load multi-switch/relay
It may be too much of an ask to recreate the original function I don’t recall exactly when, but there was some change with Smartthings that broke the official DTH, But works with official Zigbee switch DTH, with Main controlling both relays, which was fine as far as controlling both loads simultaneously i.e. 220v.
What I can do is add it as a double switch to the zigbee multi switch Mc driver.
This controller allows you to turn on and off the 2 switches individually or simultaneously.
Does will not measure power.
Good enough for me. Thanks so much Mariano!
Added to this driver version.
Try it and if not work fine tell me
β”‚ Version     β”‚ 2022-08-05T15:48:32.391308013        β”‚
Remember that this driver has the possibility in preferences settings to choose a single or multiple mosaic to show all the switches in the mosaic
  - id: "Smartenit/ZBMLC30"
    deviceLabel: Smartenit Two Switch
    model: ZBMLC30
Fantastic, will test when I have the opportunity.
A few observations:
All Switch On-Off, works as expected, activating/deactivating both relays and shows status of All On or All Off. The other switch being displayed is Switch2, which works as expected and All Switch displaying S2:On, when used while All Switch button is off. If Switch2 is activated while All Switch is on, *. the All Switch status displays S1:On and of course the first relay is remaining on/closed, while Switch2 display Off . when All Switch is pressed in this state, all switches are turned on again.
This is good enough, and I understand this logic.
Other than that, the option to choose Multi-Tile does not allow to be selected, it shows the button circle, but cannot be selected.
I am grateful to have the functions as they are presently.
I would have to look at it, but that’s how I programmed the operation of All switch On-Off.
It is only activated when all the switches are On
When pressed it will perform the opposite action to its current state.
The multiple mosaic circles of the Icon componentd are not colored, only the name becomes bold when it is activated
Ok, Multi-Tile works, now that you told me how to select it.
Ok, so now Main is showing, where it wasn’t before, so it’s better now! I don’t know if changing tile format made this happen, but now I see Main power button and timer, where before it was a cloud symbol.
Seems really good. I’ll provide more feedback if I see something strange.
Thanks again, Mariano!
Thanks so much, I can’t wait to try!
tks my friend… ill try that …
Another one:
  • application: 41
  • endpointId: 01
  • manufacturer: _TYZB01_zsl6z0pw
  • model: TS0003
    Raw Description 01 0104 0100 01 05 0000 0004 0005 0006 0006 02 0019 000A
Can you please help ?
Hi @dotan_shai
Is a three switch device?
