I accidently deleted the Main Mirror Creator tile from the app, driver is still installed. I have tried for 2 days to readd the main Creator device by scan nearby but it isn’t being discovered. Any advice?
Edited to add I have rebooted the V3 hub several times, cleared app cache and even force stopped ST app
I have published the Virtual Switches Mc-(SOS) driver on my shared channel.
Installed on your hub and perform search nearby.
A virtual switches main device will appear
Enter the device and make a driver change to Virtual SwitchesMc. All your virtual devices will move to that new main.
Delete the VirtualSwitches Mc-(SOS) driver from your hub
I’m going to leave this driver in the channel in case it happens to more users
It appears that latest ST app update did remove the option to select ENABLE or DISABLE in multi-switches when selected in THAN for automations.
Could you confirm this change? Because this kills your “mirror” solution.
@Mariano_Colmenarejo another user is asking if its possible to add assignable action to virtual dashboard driver, when switch is on to do something, like for buttons. It would be only single action, not 3.
To my knowledge, that is available for buttons only, unless you know the way of adding that without loosing current capabilities. This way, he would like to cut down on number of routines.
**New version of Virtual Switches Mc, which is renamed Aplicaciones Virtuales Mc:
At the request of users and reading in several posts about the need to store variables resulting from automations and admit or pass data from third parties, such as sharpTools, webcore… I have added:
Replace 5 virtual devices, which are used as intermediate steps of automations, for only 1
Pass values of variables resulting from another comparison dynamically
Pass text data or values that can be read by other third-party applications.
I do not use webcore or other similar apps, others can tell if it works for them and what for
Update will be done automatically and does not affect to devices created by previous version
│ Name │ Aplicaciones Virtuales Mc │
│ Version │ 2022-08-30T14:57:03.722011289 │
Could switch icon be added to the icon list and would it be possible to see from dashboard which switch is active? I use maximum five switches and it’d be useful to see which is active. This way I could use only one virtual device to run my change my modes and to see which mode is on.
That list of icons is what the app offers for the smartplug category.
I chose that category because it is the one that offers the most icons to change.
Yes, just basic switchboard, on/off icon. But more important is the dashboard. It’d be really helpful to see which is on. Now it just says any switch is on.
I’ll make a report to see if the info of the available icons to change can be added in the docs but that will depend on the review.
So far, the only related info I’ve seen published is the one in the post below, so, not all categories have the option to change the icon:
I have modified the driver so that the SwitchBoard, 2 to 5 switches, to show the switch or switches that are On in the status. (S1:On S3:On…)
If all are off then show “All Switch Off”
If all are on then show “All Switch On”
It only shows in the mosaic the Switches that are On, those that are Off are omitted. In this way, combine all the combinations in a simple mosaic. (S1:On S3:On S4:On S5:On)
│ Version │ 2022-08-31T17:04:02.238890609 │
