@Jason_Meudt,
I’m glad it works fine!
Tomorrow I will add a preference to correct the temperature offset.
I will also put a preference so that can be customized the wakeUp with the temperature update from 1 hour to 6 hours
And I will merge it to the Z-Wave Siren Mc driver
Try it today and if something doesn’t work tell me
Cheers
Cheers to you for your work! Much Thanks!
@Jason_Meudt,
I have published this version 3 with preferences for temperature offset and wakeUp interval from 1 to 24 hours, the same as DTH.
Please, when you can try it to see if it works well and does not give any error in the driver installation and changes in the preferences.
If everything works fine I will merge it to the Z-Wave Siren Mc driver
│ Driver Id │ c51a87ab-dcb9-42ba-bf9d-55d4c3b422bb │
│ Name │ Z-Wave Siren v3 │
│ Package Key │ zwave-siren-v3 │
│ Version │ 2022-04-24T18:01:39.145895 │
Looks good! Wake up defaults to 4 hours which is a decent standard.
Again, much thanks!
Thanks to the request of and @Jason_Meudt help for testing and debugging driver, I have released a new version of the Z-Wave Siren Mc driver for Ecolink Firefighter:
Improvements:
- Added Capabilities TemperaturMeasurement and TamperAlert
- A preference has been added to configure the WakeUp from 1 to 24 Hours, by default it is 4 Hours.
This will periodically update the temperature and battery.
The driver update will be done automatically in the next 12 hours
@Jason_Meudt will have update driver manually changing from your test version v3 to the definitive Mc
│ Name │ Z-Wave Siren Mc │
│ Version │ 2022-04-26T17:41:08.36624 │
Done and thank you! You can delete the V3 version now!
