(NEW RELEASE) Edge Drive Beta Z-Wave Siren Mc Modified for Ecolink Firefighter
  • Modified stock beta edge driver Z-Wave Siren for Ecolink Firefighter, fingerprint mfr:“014A”, prod:“0005”, model:“000F”
  • Added new profile with smokeDetector and carbonMonoxideDetector capabilities with SmokeDetector categories and icon so that it is correctly detected by STHM.
  • Modified the zwave-sound-sensor / init.lua subdriver in order to detect and emit:
    • Smoke Detected and sound when smoke alarm is detected
    • CO Detected and sound when CO alarm is detected
    • Smoke Detected, CO Detected and sound when smoke and CO alarms are detected
Tested by @Terri_Baker, thanks
This is the version of the modified driver:
│ Name        │ Z-Wave Siren Mc                      │
│ Version     │ 2022-03-28T10:47:12.567681           │
Link to the shared channel
SmartThings. Add a little smartness to your things
@Mariano_Colmenarejo does this problem affect the ZigBee sound sensor for the
  • zigbeeNodeType: SLEEPY_END_DEVICE
  • firmwareManufacturerCode: 4130
  • firmwareFullVersion: 03180531
  • application: 01
  • endpointId: 01
  • firmwareImageType: 4
  • manufacturer: Ecolink
  • model: FFZB1-SM-ECO
I’m no expert on these devices, but I don’t seem to have any problems detecting and handling IASZone alarms.
MC-
Can you review this driver to add the missing capabilities based on the ‘old’ DTH?
capability “Tamper Alert”
capability “Health Check”
capability “Temperature Measurement”
-Jason
Try this version, I don’t know if it will work. You will tell me!
The HealthCheck function is built into the defuatl libraries of the edge drivers automatically
│ Driver Id   │ c51a87ab-dcb9-42ba-bf9d-55d4c3b422bb │
│ Name        │ Z-Wave Siren v3                      │
│ Package Key │ zwave-siren-v3                       │
│ Version     │ 2022-04-22T09:26:54.58021            │
It’s a bit early to test the sound functions with the family sleeping…
:slight_smile:
I did not see the temp sensor capabilities in the new driver.
-JM
You will have to exit the app and try to clear the cache if it is an android phone
It just took a bit. I have an iOS phone.
The temp indicator is coming up as 0 degrees Celcius. Is there a a selection for Fahrenheit? It may also just need some time to start the actual temperature reading as well.
The tamper indicator is showing the cloud with a mark through indicator… Should it not represent CLEAR, just as the CO and SMOKE indicators?
Try doing a refresh by swiping down on the detail view.
With the DTH did it report temperature and tamper alert?
The selection of ºC or ºF is automatic with your location account
I did a refresh and no data for temp was available. The unit does have both tamper alerts and temp readings, although for the life of me, I can only remember the tamper alerts. I took a brief look a the capabilities and both are listed as well as the audio capabilities.
As far as the temperature designators (F/C), my IDE shows my coordinates, timezone and temp scale all correct with the temperature set at ‘F’. Is there another ‘place’ the driver pulls the data from?
Both for temperature and tamper alert there are handler defaults in the edge libraries and it is what the device should use, but need see the log of what the device is sending and if the device needs to configure any report parameter in the installation
The default handler reads the temperature units from the message sent by the device and if it is not reading anything, it displays ºC.
--- @param cmd st.zwave.CommandClass.SensorMultilevel.Report
local function temperature_report_handler(self, device, cmd)
  if (cmd.args.sensor_type == SensorMultilevel.sensor_type.TEMPERATURE) then
    local scale = 'C'
    if (cmd.args.scale == SensorMultilevel.scale.temperature.FAHRENHEIT) then scale = 'F' end
    device:emit_event_for_endpoint(cmd.src_channel, capabilities.temperatureMeasurement.temperature({value = cmd.args.sensor_value, unit = scale}))
  end
end
That’s why need see the logs
When I finally got back to grabbing the logs, the temp has now changed to F. The tamper alert still shows a cloud disconnected symbol. When the family wakes up, I will open to battery and see if the alert shows and clears out.
I did change drivers and then reselect the V3 version with these logs:
022-04-23T11:55:19.881256456+00:00 TRACE Z-Wave Siren v3 Setup driver zwave_siren with lifecycle handlers:
DeviceLifecycleDispatcher: zwave_siren
default_handlers:
doConfigure:
driverSwitched:
infoChanged:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_siren → multifunctional siren
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_siren → zwave sound sensor
default_handlers:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_siren → Ecolink Wireless Siren
default_handlers:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_siren → Philio sound siren
default_handlers:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_siren → aeotec-doorbell-siren
default_handlers:
added:
doConfigure:
infoChanged:
init:
child_dispatchers:
2022-04-23T11:55:19.890597122+00:00 TRACE Z-Wave Siren v3 Setup driver zwave_siren with Capability handlers:
CapabilityCommandDispatcher: zwave_siren
default_handlers:
chime:
chime
off
switch:
on
off
alarm:
off
strobe
siren
both
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zwave_siren → multifunctional siren
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_siren → zwave sound sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_siren → Ecolink Wireless Siren
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zwave_siren → Philio sound siren
default_handlers:
chime:
chime
off
switch:
on
off
alarm:
off
strobe
siren
both
child_dispatchers:
CapabilityCommandDispatcher: zwave_siren → aeotec-doorbell-siren
default_handlers:
child_dispatchers:
2022-04-23T11:55:19.902879122+00:00 TRACE Z-Wave Siren v3 Setup driver zwave_siren with Z-Wave handlers:
ZwaveDispatcher: zwave_siren
default_handlers:
SENSOR_BINARY:
REPORT
NOTIFICATION:
REPORT
WAKE_UP:
NOTIFICATION
SWITCH_BINARY:
REPORT
SWITCH_MULTILEVEL:
REPORT
BASIC:
REPORT
SENSOR_MULTILEVEL:
REPORT
BATTERY:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_siren → multifunctional siren
default_handlers:
NOTIFICATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_siren → zwave sound sensor
default_handlers:
NOTIFICATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_siren → Ecolink Wireless Siren
default_handlers:
BASIC:
SET
child_dispatchers:
ZwaveDispatcher: zwave_siren → Philio sound siren
default_handlers:
SENSOR_BINARY:
REPORT
NOTIFICATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_siren → aeotec-doorbell-siren
default_handlers:
BASIC:
REPORT
NOTIFICATION:
REPORT
child_dispatchers:
2022-04-23T11:55:19.952983789+00:00 TRACE Z-Wave Siren v3 Z-Wave Device: 0c6ad712-8281-4730-bd3b-f9213becdfe8
Manufacturer: 0x014A Product Type: 0x0005 Product ID: 0x000F
[0]: ZWAVEPLUS_INFO, VERSION, MANUFACTURER_SPECIFIC, DEVICE_RESET_LOCALLY, POWERLEVEL, BATTERY, SENSOR_MULTILEVEL, NOTIFICATION, ASSOCIATION, ASSOCIATION_GRP_INFO, WAKE_UP, CONFIGURATION, FIRMWARE_UPDATE_MD
2022-04-23T11:55:19.961054456+00:00 TRACE Z-Wave Siren v3 Received event with handler _resync
2022-04-23T11:55:19.966839789+00:00 TRACE Z-Wave Siren v3 Received event with handler environment_info
2022-04-23T11:55:19.982530456+00:00 TRACE Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received unhandled lifecycle event: init
2022-04-23T11:55:19.988222789+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T11:55:19.994326789+00:00 TRACE Z-Wave Siren v3 Received event with handler environment_info
2022-04-23T11:55:20.000314122+00:00 DEBUG Z-Wave Siren v3 Z-Wave hub node ID environment changed.
2022-04-23T11:55:20.007818789+00:00 TRACE Z-Wave Siren v3 Received event with handler device_lifecycle
2022-04-23T11:55:20.013763789+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received lifecycle event: added
2022-04-23T11:55:20.023611456+00:00 TRACE Z-Wave Siren v3 Found DeviceLifecycleDispatcher handler in zwave_siren → zwave sound sensor
2022-04-23T11:55:20.030061122+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“sound”,“capability_id”:“soundSensor”,“component_id”:“main”,“state”:{“value”:“not detected”}}
2022-04-23T11:55:20.051201456+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“smoke”,“capability_id”:“smokeDetector”,“component_id”:“main”,“state”:{“value”:“clear”}}
2022-04-23T11:55:20.076797789+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“carbonMonoxide”,“capability_id”:“carbonMonoxideDetector”,“component_id”:“main”,“state”:{“value”:“clear”}}
2022-04-23T11:55:20.095763456+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T11:55:20.102072456+00:00 TRACE Z-Wave Siren v3 Received event with handler device_lifecycle
2022-04-23T11:55:20.111046123+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received lifecycle event: driverSwitched
2022-04-23T11:55:20.127491456+00:00 TRACE Z-Wave Siren v3 Found DeviceLifecycleDispatcher handler in zwave_siren
2022-04-23T11:55:20.133323456+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T11:55:20.483811456+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T11:55:20.608455456+00:00 TRACE Z-Wave Siren v3 Received event with handler device_lifecycle
2022-04-23T11:55:20.624787123+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received lifecycle event: infoChanged
2022-04-23T11:55:20.634853789+00:00 TRACE Z-Wave Siren v3 Found DeviceLifecycleDispatcher handler in zwave_siren
2022-04-23T11:55:20.640839789+00:00 PRINT Z-Wave Siren v3 Memory >>>>>>> 1481.8115234375 Kbytes
2022-04-23T11:55:20.646894456+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T11:55:33.941184796+00:00 TRACE Z-Wave Siren v3 Received event with handler capability
2022-04-23T11:55:33.951047129+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received command: {“args”:{},“capability”:“refresh”,“command”:“refresh”,“component”:“main”,“positional_args”:{}}
2022-04-23T11:55:33.961086796+00:00 TRACE Z-Wave Siren v3 Found CapabilityCommandDispatcher handler in zwave_siren
2022-04-23T11:55:33.974032796+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={}, cmd_class=“BATTERY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="", src_channel=0, version=1}
2022-04-23T11:55:33.993436129+00:00 TRACE Z-Wave Siren v3 Z-Wave command(0e76469f) queued for radio transmission: CC:Battery, CID:0x02
2022-04-23T11:55:34.014807129+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={scale=0, sensor_type=“TEMPERATURE”}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="\x01\x00", src_channel=0, version=5}
2022-04-23T11:55:34.024422796+00:00 TRACE Z-Wave Siren v3 Z-Wave command(4897c84f) queued for radio transmission: CC:Sensor Multi-level, CID:0x04
2022-04-23T11:55:34.030633462+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T11:55:41.362960799+00:00 TRACE Z-Wave Siren v3 Z-Wave command(0e76469f) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-04-23T11:55:48.572992469+00:00 TRACE Z-Wave Siren v3 Z-Wave command(4897c84f) transmit status: TRANSMIT_COMPLETE_NO_ACK
The driver Get the temperature and Battery when refresh performed, but there is no acknowledgment.
Device may be asleep and need a wakeUp setup.
I don’t know the device, I can send it a periodic configuration of wakeUp to see what happens. The DTh has it for a minimum of 1 hour so as not to overuse the battery.
I can put a wake up of 15 minutes to test if it works.
When I have it done I’ll let you know
@Jason_Meudt,
I put a wakeUp configuration = 900 sec
If it works then I will put it in 3600 sec
You can install this version with the CLI without uninstalling the device
│ Version     │ 2022-04-23T15:25:52.723393           │
Updated the driver and also performed a tamper check… Logs indicate a tamper, although the driver result in the App do not indicate as such…sample log event in BOLD.
2022-04-23T15:47:04.932822412+00:00 TRACE Z-Wave Siren v3 Z-Wave Device: 0c6ad712-8281-4730-bd3b-f9213becdfe8
2022-04-23T15:47:04.940596412+00:00 TRACE Z-Wave Siren v3 Received event with handler _resync
2022-04-23T15:47:04.946615079+00:00 TRACE Z-Wave Siren v3 Received event with handler environment_info
2022-04-23T15:47:04.962557412+00:00 TRACE Z-Wave Siren v3 Found DeviceLifecycleDispatcher handler in zwave_siren → zwave sound sensor
2022-04-23T15:47:04.970122745+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={node_id=0, seconds=900}, cmd_class=“WAKE_UP”, cmd_id=“INTERVAL_SET”, dst_channels={}, encap=“AUTO”, payload="\x00\x03\x84\x00", src_channel=0, version=1}
2022-04-23T15:47:04.979298412+00:00 TRACE Z-Wave Siren v3 Z-Wave command(e7775f83) queued for radio transmission: CC:Wake Up, CID:0x04
2022-04-23T15:47:04.984948412+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:47:04.991228079+00:00 TRACE Z-Wave Siren v3 Received event with handler environment_info
2022-04-23T15:47:04.996794412+00:00 DEBUG Z-Wave Siren v3 Z-Wave hub node ID environment changed.
2022-04-23T15:47:05.004141412+00:00 TRACE Z-Wave Siren v3 Received event with handler device_lifecycle
2022-04-23T15:47:05.009963079+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received lifecycle event: added
2022-04-23T15:47:05.019201079+00:00 TRACE Z-Wave Siren v3 Found DeviceLifecycleDispatcher handler in zwave_siren → zwave sound sensor
2022-04-23T15:47:05.025630412+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“sound”,“capability_id”:“soundSensor”,“component_id”:“main”,“state”:{“value”:“not detected”}}
2022-04-23T15:47:05.050464745+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“smoke”,“capability_id”:“smokeDetector”,“component_id”:“main”,“state”:{“value”:“clear”}}
2022-04-23T15:47:05.073581745+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“carbonMonoxide”,“capability_id”:“carbonMonoxideDetector”,“component_id”:“main”,“state”:{“value”:“clear”}}
2022-04-23T15:47:05.095964745+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:47:05.104009745+00:00 TRACE Z-Wave Siren v3 Received event with handler device_lifecycle
2022-04-23T15:47:05.109767745+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received lifecycle event: driverSwitched
2022-04-23T15:47:05.128014079+00:00 TRACE Z-Wave Siren v3 Found DeviceLifecycleDispatcher handler in zwave_siren
2022-04-23T15:47:05.133946745+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:47:05.150103412+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:47:05.663225412+00:00 TRACE Z-Wave Siren v3 Received event with handler device_lifecycle
2022-04-23T15:47:05.679367079+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received lifecycle event: infoChanged
2022-04-23T15:47:05.689798079+00:00 TRACE Z-Wave Siren v3 Found DeviceLifecycleDispatcher handler in zwave_siren
2022-04-23T15:47:05.696014412+00:00 PRINT Z-Wave Siren v3 Memory >>>>>>> 1500.6396484375 Kbytes
2022-04-23T15:47:05.702025079+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:47:12.364301416+00:00 TRACE Z-Wave Siren v3 Z-Wave command(e7775f83) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-04-23T15:47:52.182395768+00:00 TRACE Z-Wave Siren v3 Received event with handler capability
2022-04-23T15:47:52.191468435+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received command: {“args”:{},“capability”:“refresh”,“command”:“refresh”,“component”:“main”,“positional_args”:{}}
2022-04-23T15:47:52.202207101+00:00 TRACE Z-Wave Siren v3 Found CapabilityCommandDispatcher handler in zwave_siren
2022-04-23T15:47:52.215040435+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={}, cmd_class=“BATTERY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="", src_channel=0, version=1}
2022-04-23T15:47:52.224445768+00:00 TRACE Z-Wave Siren v3 Z-Wave command(da8d5f9c) queued for radio transmission: CC:Battery, CID:0x02
2022-04-23T15:47:52.241078768+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={scale=0, sensor_type=“TEMPERATURE”}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="\x01\x00", src_channel=0, version=5}
2022-04-23T15:47:52.252664435+00:00 TRACE Z-Wave Siren v3 Z-Wave command(9298fda5) queued for radio transmission: CC:Sensor Multi-level, CID:0x04
2022-04-23T15:47:52.265897768+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:47:59.584202438+00:00 TRACE Z-Wave Siren v3 Z-Wave command(da8d5f9c) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-04-23T15:48:06.884162108+00:00 TRACE Z-Wave Siren v3 Z-Wave command(9298fda5) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-04-23T15:48:42.002406174+00:00 TRACE Z-Wave Siren v3 Received event with handler capability
2022-04-23T15:48:42.011445508+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received command: {“args”:{},“capability”:“refresh”,“command”:“refresh”,“component”:“main”,“positional_args”:{}}
2022-04-23T15:48:42.022195841+00:00 TRACE Z-Wave Siren v3 Found CapabilityCommandDispatcher handler in zwave_siren
2022-04-23T15:48:42.031887174+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={}, cmd_class=“BATTERY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="", src_channel=0, version=1}
2022-04-23T15:48:42.044436174+00:00 TRACE Z-Wave Siren v3 Z-Wave command(fccc8652) queued for radio transmission: CC:Battery, CID:0x02
2022-04-23T15:48:42.056861174+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={scale=0, sensor_type=“TEMPERATURE”}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="\x01\x00", src_channel=0, version=5}
2022-04-23T15:48:42.067841841+00:00 TRACE Z-Wave Siren v3 Z-Wave command(a32c7271) queued for radio transmission: CC:Sensor Multi-level, CID:0x04
2022-04-23T15:48:42.073807841+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:48:49.484164845+00:00 TRACE Z-Wave Siren v3 Z-Wave command(fccc8652) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-04-23T15:48:56.854223181+00:00 TRACE Z-Wave Siren v3 Z-Wave command(a32c7271) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-04-23T15:50:26.422554557+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
> 2022-04-23T15:50:26.444568224+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={alarm_level=0, alarm_type=0, event=“TAMPERING_PRODUCT_COVER_REMOVED”, event_parameter="", notification_status=“ON”, notification_type=“HOME_SECURITY”, v1_alarm_level=0, v1_alarm_type=0, z_wave_alarm_event=“TAMPERING_PRODUCT_COVER_REMOVED”, z_wave_alarm_status=“ON”, z_wave_alarm_type=“BURGLAR”, zensor_net_source_node_id=0}, cmd_class=“NOTIFICATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="\x00\x00\x00\xFF\x07\x03\x00\x00", src_channel=0, version=3}
2022-04-23T15:50:26.455156224+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren → zwave sound sensor
2022-04-23T15:50:26.462325224+00:00 PRINT Z-Wave Siren v3 alarm_type >>>>> 7
2022-04-23T15:50:26.468766891+00:00 PRINT Z-Wave Siren v3 alarm_event >>>>> 3
2022-04-23T15:50:26.482208558+00:00 PRINT Z-Wave Siren v3 <<<< NO SMOKE & NO CO >>>>>
2022-04-23T15:50:26.489371224+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“sound”,“capability_id”:“soundSensor”,“component_id”:“main”,“state”:{“value”:“not detected”}}
2022-04-23T15:50:26.522194558+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“carbonMonoxide”,“capability_id”:“carbonMonoxideDetector”,“component_id”:“main”,“state”:{“value”:“clear”}}
2022-04-23T15:50:26.555567558+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“smoke”,“capability_id”:“smokeDetector”,“component_id”:“main”,“state”:{“value”:“clear”}}
2022-04-23T15:50:26.583049224+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:50:50.102429902+00:00 TRACE Z-Wave Siren v3 Received event with handler capability
2022-04-23T15:50:50.122222235+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received command: {“args”:{},“capability”:“refresh”,“command”:“refresh”,“component”:“main”,“positional_args”:{}}
2022-04-23T15:50:50.130605569+00:00 TRACE Z-Wave Siren v3 Found CapabilityCommandDispatcher handler in zwave_siren
2022-04-23T15:50:50.142213902+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={}, cmd_class=“BATTERY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="", src_channel=0, version=1}
2022-04-23T15:50:50.151234902+00:00 TRACE Z-Wave Siren v3 Z-Wave command(08299193) queued for radio transmission: CC:Battery, CID:0x02
2022-04-23T15:50:50.168132902+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={scale=0, sensor_type=“TEMPERATURE”}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="\x01\x00", src_channel=0, version=5}
2022-04-23T15:50:50.177360569+00:00 TRACE Z-Wave Siren v3 Z-Wave command(00a05c8f) queued for radio transmission: CC:Sensor Multi-level, CID:0x04
2022-04-23T15:50:50.183682902+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:50:50.254901569+00:00 TRACE Z-Wave Siren v3 Z-Wave command(08299193) transmit status: TRANSMIT_COMPLETE_OK
2022-04-23T15:50:50.264406902+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
2022-04-23T15:50:50.276079236+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={battery_level=100}, cmd_class=“BATTERY”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“d”, src_channel=0, version=1}
2022-04-23T15:50:50.286217902+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T15:50:50.292901236+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:100}}
2022-04-23T15:50:50.311358569+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:50:50.424457902+00:00 TRACE Z-Wave Siren v3 Z-Wave command(00a05c8f) transmit status: TRANSMIT_COMPLETE_OK
2022-04-23T15:50:50.670582902+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
2022-04-23T15:50:50.679071902+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={precision=2, scale=“CELSIUS”, sensor_type=“TEMPERATURE”, sensor_value=23.7, size=2}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="\x01\x42\x09\x42", src_channel=0, version=1}
2022-04-23T15:50:50.694570569+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T15:50:50.701123569+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:23.7}}
2022-04-23T15:50:50.719976902+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T15:50:50.725736569+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:51:37.980185925+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
2022-04-23T15:51:38.267865592+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={alarm_level=0, alarm_type=0, event=“STATE_IDLE”, event_parameter="", notification_status=“ON”, notification_type=“HOME_SECURITY”, v1_alarm_level=0, v1_alarm_type=0, z_wave_alarm_event=0, z_wave_alarm_status=“ON”, z_wave_alarm_type=“BURGLAR”, zensor_net_source_node_id=0}, cmd_class=“NOTIFICATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="\x00\x00\x00\xFF\x07\x00\x00\x00", src_channel=0, version=3}
2022-04-23T15:51:38.297778258+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren → zwave sound sensor
2022-04-23T15:51:38.312651592+00:00 PRINT Z-Wave Siren v3 alarm_type >>>>> 7
2022-04-23T15:51:38.324837258+00:00 PRINT Z-Wave Siren v3 alarm_event >>>>> 0
2022-04-23T15:51:38.334720258+00:00 PRINT Z-Wave Siren v3 <<<< NO SMOKE & NO CO >>>>>
2022-04-23T15:51:38.347284592+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“sound”,“capability_id”:“soundSensor”,“component_id”:“main”,“state”:{“value”:“not detected”}}
2022-04-23T15:51:38.382875925+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“carbonMonoxide”,“capability_id”:“carbonMonoxideDetector”,“component_id”:“main”,“state”:{“value”:“clear”}}
2022-04-23T15:51:38.422206258+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“smoke”,“capability_id”:“smokeDetector”,“component_id”:“main”,“state”:{“value”:“clear”}}
2022-04-23T15:51:38.455579592+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:51:38.461647259+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
2022-04-23T15:51:38.482004259+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={}, cmd_class=“WAKE_UP”, cmd_id=“NOTIFICATION”, dst_channels={}, encap=“NONE”, payload="", src_channel=0, version=1}
2022-04-23T15:51:38.499533592+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T15:51:38.515233592+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T15:51:38.522888925+00:00 TRACE Z-Wave Siren v3 Found CapabilityCommandDispatcher handler in zwave_siren
2022-04-23T15:51:38.537308925+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={}, cmd_class=“BATTERY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="", src_channel=0, version=1}
2022-04-23T15:51:38.551861592+00:00 TRACE Z-Wave Siren v3 Z-Wave command(b68435b8) queued for radio transmission: CC:Battery, CID:0x02
2022-04-23T15:51:38.562511592+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={scale=0, sensor_type=“TEMPERATURE”}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="\x01\x00", src_channel=0, version=5}
2022-04-23T15:51:38.574118259+00:00 TRACE Z-Wave Siren v3 Z-Wave command(1a6582b1) queued for radio transmission: CC:Sensor Multi-level, CID:0x04
2022-04-23T15:51:38.587303259+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:51:38.754907925+00:00 TRACE Z-Wave Siren v3 Z-Wave command(b68435b8) transmit status: TRANSMIT_COMPLETE_OK
2022-04-23T15:51:38.764403925+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
2022-04-23T15:51:38.776015925+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={battery_level=100}, cmd_class=“BATTERY”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“d”, src_channel=0, version=1}
2022-04-23T15:51:38.786017259+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T15:51:38.792673925+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:100}}
2022-04-23T15:51:38.810961925+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T15:51:38.954934259+00:00 TRACE Z-Wave Siren v3 Z-Wave command(1a6582b1) transmit status: TRANSMIT_COMPLETE_OK
2022-04-23T15:51:38.963987925+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
2022-04-23T15:51:38.972192592+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={precision=2, scale=“CELSIUS”, sensor_type=“TEMPERATURE”, sensor_value=24.5, size=2}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="\x01\x42\x09\x92", src_channel=0, version=1}
2022-04-23T15:51:38.988669592+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T15:51:38.995327259+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:24.5}}
2022-04-23T15:51:39.014204592+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T15:51:39.021869259+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
Okay,
I think that what is missing is to write a code to emit the event, since it is an alert type and only handles smoke and CO.
I think that it also sends the temperature, but I think that in ºC, is that so?
@Jason_Meudt,
Try thisdate version v3.
Tamper Alert must works fine now
│ Version     │ 2022-04-23T16:21:26.930559           │
I see the temp at F within the App. Here is a screenshot…
Google Photos
Ok,
Then the automatic conversion to ºF works fine
Please, try the Tamper alert with new driver version when you can
Looks Good! I see tamper results in the History as well! Unamed handler in the logs?
2022-04-23T16:49:10.462558896+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
2022-04-23T16:49:10.484553562+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={alarm_level=0, alarm_type=0, event=“TAMPERING_PRODUCT_COVER_REMOVED”, event_parameter="", notification_status=“ON”, notification_type=“HOME_SECURITY”, v1_alarm_level=0, v1_alarm_type=0, z_wave_alarm_event=“TAMPERING_PRODUCT_COVER_REMOVED”, z_wave_alarm_status=“ON”, z_wave_alarm_type=“BURGLAR”, zensor_net_source_node_id=0}, cmd_class=“NOTIFICATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="\x00\x00\x00\xFF\x07\x03\x00\x00", src_channel=0, version=3}
2022-04-23T16:49:10.494615229+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren → zwave sound sensor
2022-04-23T16:49:10.502195562+00:00 PRINT Z-Wave Siren v3 alarm_type >>>>> 7
2022-04-23T16:49:10.508670562+00:00 PRINT Z-Wave Siren v3 alarm_event >>>>> 3
2022-04-23T16:49:10.519192562+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“tamper”,“capability_id”:“tamperAlert”,“component_id”:“main”,“state”:{“value”:“detected”}}
2022-04-23T16:49:10.553523229+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T16:49:18.430950566+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
2022-04-23T16:49:18.453881566+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={alarm_level=0, alarm_type=0, event=“STATE_IDLE”, event_parameter="", notification_status=“ON”, notification_type=“HOME_SECURITY”, v1_alarm_level=0, v1_alarm_type=0, z_wave_alarm_event=0, z_wave_alarm_status=“ON”, z_wave_alarm_type=“BURGLAR”, zensor_net_source_node_id=0}, cmd_class=“NOTIFICATION”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="\x00\x00\x00\xFF\x07\x00\x00\x00", src_channel=0, version=3}
2022-04-23T16:49:18.474118233+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren → zwave sound sensor
2022-04-23T16:49:18.479859566+00:00 PRINT Z-Wave Siren v3 alarm_type >>>>> 7
2022-04-23T16:49:18.486018899+00:00 PRINT Z-Wave Siren v3 alarm_event >>>>> 0
2022-04-23T16:49:18.492697233+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“tamper”,“capability_id”:“tamperAlert”,“component_id”:“main”,“state”:{“value”:“clear”}}
2022-04-23T16:49:18.512319233+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T16:49:18.518607899+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
2022-04-23T16:49:18.527787899+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={}, cmd_class=“WAKE_UP”, cmd_id=“NOTIFICATION”, dst_channels={}, encap=“NONE”, payload="", src_channel=0, version=1}
2022-04-23T16:49:18.543612566+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T16:49:18.549252233+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T16:49:18.556509899+00:00 TRACE Z-Wave Siren v3 Found CapabilityCommandDispatcher handler in zwave_siren
2022-04-23T16:49:18.565990233+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={}, cmd_class=“BATTERY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="", src_channel=0, version=1}
2022-04-23T16:49:18.575994233+00:00 TRACE Z-Wave Siren v3 Z-Wave command(c587d2dc) queued for radio transmission: CC:Battery, CID:0x02
2022-04-23T16:49:18.583769899+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> sending Z-Wave command: {args={scale=0, sensor_type=“TEMPERATURE”}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload="\x01\x00", src_channel=0, version=5}
2022-04-23T16:49:18.592126233+00:00 TRACE Z-Wave Siren v3 Z-Wave command(f8f774c8) queued for radio transmission: CC:Sensor Multi-level, CID:0x04
2022-04-23T16:49:18.598027233+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T16:49:18.714832566+00:00 TRACE Z-Wave Siren v3 Z-Wave command(c587d2dc) transmit status: TRANSMIT_COMPLETE_OK
2022-04-23T16:49:18.726546233+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
2022-04-23T16:49:18.738832899+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={battery_level=100}, cmd_class=“BATTERY”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload=“d”, src_channel=0, version=1}
2022-04-23T16:49:18.748053233+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T16:49:18.754596233+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:100}}
2022-04-23T16:49:18.774532566+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
2022-04-23T16:49:18.794188899+00:00 TRACE Z-Wave Siren v3 Z-Wave command(f8f774c8) transmit status: TRANSMIT_COMPLETE_OK
2022-04-23T16:49:18.970568900+00:00 TRACE Z-Wave Siren v3 Received event with handler unnamed
2022-04-23T16:49:18.978934233+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> received Z-Wave command: {args={precision=2, scale=“CELSIUS”, sensor_type=“TEMPERATURE”, sensor_value=25.7, size=2}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“REPORT”, dst_channels={}, encap=“NONE”, payload="\x01\x42\x0A\x0A", src_channel=0, version=1}
2022-04-23T16:49:18.995526233+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T16:49:19.002171900+00:00 INFO Z-Wave Siren v3 <ZwaveDevice: 0c6ad712-8281-4730-bd3b-f9213becdfe8 [09] (Ecolink Firefighter)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:25.7}}
2022-04-23T16:49:19.021922900+00:00 TRACE Z-Wave Siren v3 Found ZwaveDispatcher handler in zwave_siren
2022-04-23T16:49:19.029609233+00:00 DEBUG Z-Wave Siren v3 Ecolink Firefighter device thread event handled
