(EDGE Driver-Mc): Z-Wave Edge Drivers and others with FIBARO devices:
I tried again and this is what Hub found it
It has been paired with nothing in particular
This usually happens to me when the device is very far from the hub
Now it works perfectly again. I uninstalled edge drivers and unpaired and repaired device. Device paired as “Switch” with hubs internal driver or something. Edge drivers are not in use. But how long? Let see what happends in next few months, when edge drivers are forced to use.
Keyword for find purpose:
Aeon Labs Smart Energy Switch (for DSB06xxx-ZWUS/DSC24-ZWAU/DSC24-ZWEU)
Aeon Labs DSC06106
But did you try to do the same with the driver version that I modified?
That version sends the same configuration as the DTH.
You have to exclude the device, install only the modified driver and include the device again.
In the photo you send, is it without charge?, since it is on and does not measure power
Yes I tested the modified driver, but wattage/powervalues still not refreshing continously. SmartThings Driver (Beta) driver refreshed every time when pushed physical Switch button. I checked that new version was in use.
Whats interesting I uninstalled those two drivers below. After that also Z-wave Thing Mc and SmartThings Driver (Beta) disappeared. I dont know what happends there.
I can test modified driver one more time later this evening. Maybe there is some ghost data in Samsung Cloud.
Hi @lewisburgess,
I’m trying to replicate your settings but with a few minor HW differences.
I have some spare dimmer 2 units, so had hoped to re-purpose one as a smart button to trigger various events without a connected load.
I have a “centre off” retractive switch (MK K4900) with S1 connected to L1 and S2 connected to L2, Pushing in the top or bottom gives a momentary switch to either S1 or S2.
I have live & neutral at my FGD-212 so these are both connected directly, then the Sx, S1 & S2 are connected to Common, L1 and L2 of the switch.
I have tried to create a routing based on button 1 pushed (or button 2 pushed) but these do not seem to work.
There is no load connected to the Fibaro unit so not sure if this makes a difference?
I’m using the latest version of @Mariano_Colmenarejo drivers: 2022-09-23 with Z-Wave Switch Mc.
Thanks,
Declan.
@makrisn
Please delete the post for fibaro open close sensor and paste in this thread
Hi @Mariano_Colmenarejo . Let me know if this is what you are looking for (first time working with ST CIL)
2022-11-30T15:05:23.426344893+00:00 PRINT Z-Wave Sensor and Child Thermostat Mc <<<<< Temperature Timer >>>>
2022-11-30T15:05:23.429588768+00:00 PRINT Z-Wave Sensor and Child Thermostat Mc <<< Waiting Temperature event >>>
2022-11-30T15:05:23.433793559+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a505ccae-0cd4-46af-a0e8-ea1cae35b181 [3C] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={scale=0, sensor_type=“TEMPERATURE”}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x00”, src_channel=0, version=5}
2022-11-30T15:05:23.440738059+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(30d9c19a) queued for radio transmission: CC:Sensor Multi-level, CID:0x04
2022-11-30T15:05:23.463574518+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Thermostat-Fibaro Open/Closed Sensor device thread event handled
2022-11-30T15:05:28.506046643+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(30d9c19a) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-11-30T15:10:23.427849616+00:00 PRINT Z-Wave Sensor and Child Thermostat Mc <<<<< Temperature Timer >>>>
2022-11-30T15:10:23.431094949+00:00 PRINT Z-Wave Sensor and Child Thermostat Mc <<< Waiting Temperature event >>>
2022-11-30T15:10:23.435271199+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a505ccae-0cd4-46af-a0e8-ea1cae35b181 [3C] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={scale=0, sensor_type=“TEMPERATURE”}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x00”, src_channel=0, version=5}
2022-11-30T15:10:23.442297116+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(a7f50aac) queued for radio transmission: CC:Sensor Multi-level, CID:0x04
2022-11-30T15:10:23.463570324+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Thermostat-Fibaro Open/Closed Sensor device thread event handled
2022-11-30T15:10:28.475990948+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(a7f50aac) transmit status: TRANSMIT_COMPLETE_NO_ACK
2022-11-30T15:15:23.427468714+00:00 PRINT Z-Wave Sensor and Child Thermostat Mc <<<<< Temperature Timer >>>>
2022-11-30T15:15:23.430693672+00:00 PRINT Z-Wave Sensor and Child Thermostat Mc <<< Waiting Temperature event >>>
2022-11-30T15:15:23.434869339+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a505ccae-0cd4-46af-a0e8-ea1cae35b181 [3C] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={scale=0, sensor_type=“TEMPERATURE”}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x00”, src_channel=0, version=5}
2022-11-30T15:15:23.442066547+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(8b719b1e) queued for radio transmission: CC:Sensor Multi-level, CID:0x04
2022-11-30T15:15:23.444997714+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Thermostat-Fibaro Open/Closed Sensor device thread event handled
2022-11-30T15:15:28.516009964+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(8b719b1e) transmit status: TRANSMIT_COMPLETE_NO_ACK
Hi @Mariano_Colmenarejo. It’s fairly long.
2022-11-30T17:47:03.610310066+00:00 DEBUG RDG - Zigbee Temp driver device thread event handled
2022-11-30T17:47:06.466874358+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Setup driver zwave_sensor with lifecycle handlers:
DeviceLifecycleDispatcher: zwave_sensor
default_handlers:
added:
doConfigure:
init:
infoChanged:
driverSwitched:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → zooz 4 in 1 sensor
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → Vision motion detector
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → fibaro flood sensor
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → zwave water temp humidity sensor
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → glentronics water leak sensor
default_handlers:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → homeseer multi sensor
default_handlers:
added:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → fibaro door window sensor
default_handlers:
added:
doConfigure:
init:
infoChanged:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → fibaro door window sensor → fibaro door window sensor 1
default_handlers:
added:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → fibaro door window sensor → fibaro door window sensor 2
default_handlers:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → sensative_strip
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → enerwave_motion_sensor
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → aeotec multisensor
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → aeotec multisensor → aeotec multisensor 6
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → aeotec multisensor → aeotec multisensor 7
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → Water Leak Sensor
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → Everspring Motion Light
default_handlers:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → EZmultiPli Multipurpose Sensor
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_sensor → Thermostat subdriver
default_handlers:
added:
init:
infoChanged:
removed:
child_dispatchers:
2022-11-30T17:47:06.474045233+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Setup driver zwave_sensor with Capability handlers:
CapabilityCommandDispatcher: zwave_sensor
default_handlers:
energyMeter:
resetEnergyMeter
colorControl:
setColor
setSaturation
setHue
refresh:
refresh
switch:
on
off
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → zooz 4 in 1 sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → Vision motion detector
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → fibaro flood sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → zwave water temp humidity sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → glentronics water leak sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → homeseer multi sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → fibaro door window sensor
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → fibaro door window sensor → fibaro door window sensor 1
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → fibaro door window sensor → fibaro door window sensor 2
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → sensative_strip
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → enerwave_motion_sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → aeotec multisensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → aeotec multisensor → aeotec multisensor 6
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → aeotec multisensor → aeotec multisensor 7
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → Water Leak Sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → Everspring Motion Light
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → EZmultiPli Multipurpose Sensor
default_handlers:
colorControl:
setColor
child_dispatchers:
CapabilityCommandDispatcher: zwave_sensor → Thermostat subdriver
default_handlers:
thermostatCoolingSetpoint:
setCoolingSetpoint
refresh:
refresh
thermostatHeatingSetpoint:
setHeatingSetpoint
thermostatMode:
setThermostatMode
thermostatFanMode:
setThermostatFanMode
legendabsolute60149.thermostatLocked:
setThermostatLocked
child_dispatchers:
2022-11-30T17:47:06.482068774+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Setup driver zwave_sensor with Z-Wave handlers:
ZwaveDispatcher: zwave_sensor
default_handlers:
BASIC:
REPORT
SENSOR_MULTILEVEL:
REPORT
METER:
REPORT
SWITCH_COLOR:
REPORT
WAKE_UP:
NOTIFICATION
SWITCH_BINARY:
REPORT
SWITCH_MULTILEVEL:
REPORT
SENSOR_ALARM:
REPORT
SENSOR_BINARY:
REPORT
NOTIFICATION:
REPORT
BATTERY:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → zooz 4 in 1 sensor
default_handlers:
NOTIFICATION:
REPORT
SENSOR_MULTILEVEL:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → Vision motion detector
default_handlers:
NOTIFICATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → fibaro flood sensor
default_handlers:
SENSOR_BINARY:
REPORT
SENSOR_MULTILEVEL:
REPORT
SENSOR_ALARM:
REPORT
BASIC:
SET
child_dispatchers:
ZwaveDispatcher: zwave_sensor → zwave water temp humidity sensor
default_handlers:
NOTIFICATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → glentronics water leak sensor
default_handlers:
NOTIFICATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → homeseer multi sensor
default_handlers:
BASIC:
SET
child_dispatchers:
ZwaveDispatcher: zwave_sensor → fibaro door window sensor
default_handlers:
CONFIGURATION:
REPORT
SENSOR_MULTILEVEL:
REPORT
NOTIFICATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → fibaro door window sensor → fibaro door window sensor 1
default_handlers:
SENSOR_ALARM:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → fibaro door window sensor → fibaro door window sensor 2
default_handlers:
NOTIFICATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → sensative_strip
default_handlers:
WAKE_UP:
NOTIFICATION
CONFIGURATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → enerwave_motion_sensor
default_handlers:
WAKE_UP:
NOTIFICATION
child_dispatchers:
ZwaveDispatcher: zwave_sensor → aeotec multisensor
default_handlers:
NOTIFICATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → aeotec multisensor → aeotec multisensor 6
default_handlers:
CONFIGURATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → aeotec multisensor → aeotec multisensor 7
default_handlers:
CONFIGURATION:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → Water Leak Sensor
default_handlers:
BASIC:
SET
child_dispatchers:
ZwaveDispatcher: zwave_sensor → Everspring Motion Light
default_handlers:
child_dispatchers:
ZwaveDispatcher: zwave_sensor → EZmultiPli Multipurpose Sensor
default_handlers:
BASIC:
REPORT
child_dispatchers:
ZwaveDispatcher: zwave_sensor → Thermostat subdriver
default_handlers:
child_dispatchers:
2022-11-30T17:47:06.508063483+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave Device: a9710043-7434-4115-876e-568f8f43255a
Manufacturer: 0x010F Product Type: 0x0700 Product ID: 0x2000
[0]: SCENE_ACTIVATION, SENSOR_BINARY, SENSOR_ALARM, MULTI_CHANNEL, ASSOCIATION, MANUFACTURER_SPECIFIC, CONFIGURATION, VERSION, BATTERY, CRC_16_ENCAP, WAKE_UP, FIRMWARE_UPDATE_MD [1]: SCENE_ACTIVATION, SENSOR_BINARY, SENSOR_ALARM, MULTI_CHANNEL, ASSOCIATION, MANUFACTURER_SPECIFIC, CONFIGURATION, VERSION, BATTERY, CRC_16_ENCAP, WAKE_UP, FIRMWARE_UPDATE_MD
2022-11-30T17:47:06.512508983+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Received event with handler _resync
2022-11-30T17:47:06.515487274+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Received event with handler environment_info
2022-11-30T17:47:06.527639566+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found DeviceLifecycleDispatcher handler in zwave_sensor → fibaro door window sensor
2022-11-30T17:47:06.530728983+00:00 PRINT Z-Wave Sensor and Child Thermostat Mc Parent_devices[a9710043-7434-4115-876e-568f8f43255a]>>>>>> <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)>
2022-11-30T17:47:06.535276191+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Fibaro Open/Closed Sensor device thread event handled
2022-11-30T17:47:06.563764733+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Received event with handler environment_info
2022-11-30T17:47:06.566746066+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Z-Wave hub node ID environment changed.2022-11-30T17:47:06.575613066+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Received event with handler device_lifecycle
2022-11-30T17:47:06.578599024+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> received lifecycle event: added
2022-11-30T17:47:06.586250858+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found DeviceLifecycleDispatcher handler in zwave_sensor → fibaro door window sensor
2022-11-30T17:47:06.592356899+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found CapabilityCommandDispatcher handler in zwave_sensor → fibaro door window sensor
2022-11-30T17:47:06.595646066+00:00 PRINT Z-Wave Sensor and Child Thermostat Mc <<< Refresh >>>
2022-11-30T17:47:06.604280983+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={scale=0, sensor_type=“TEMPERATURE”}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x00”, src_channel=0, version=5}
2022-11-30T17:47:06.611574108+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(0e4536da) queued for radio transmission: CC:Sensor Multi-level, CID:0x04
2022-11-30T17:47:06.615194066+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={}, cmd_class=“BATTERY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“”, src_channel=0, version=1}
2022-11-30T17:47:06.621825108+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(4a83c0ee) queued for radio transmission: CC:Battery, CID:0x02
2022-11-30T17:47:06.625877566+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={sensor_type=“DOOR_WINDOW”}, cmd_class=“SENSOR_BINARY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x0A”, src_channel=0, version=2}
2022-11-30T17:47:06.632802316+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(f7cb2ee4) queued for radio transmission: CC:Sensor Binary, CID:0x02
2022-11-30T17:47:06.640468899+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={sensor_type=“GENERAL_PURPOSE_ALARM”}, cmd_class=“SENSOR_ALARM”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x00”, src_channel=0, version=1}
2022-11-30T17:47:06.647041816+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(db36df4f) queued for radio transmission: CC:Sensor Alarm, CID:0x01
2022-11-30T17:47:06.651005733+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={sensor_type=“TAMPER”}, cmd_class=“SENSOR_BINARY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x08”, src_channel=0, version=2}
2022-11-30T17:47:06.658177566+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(fb75184f) queued for radio transmission: CC:Sensor Binary, CID:0x02
2022-11-30T17:47:06.661565316+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Fibaro Open/Closed Sensor device thread event handled
2022-11-30T17:47:06.664590608+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Received event with handler device_lifecycle
2022-11-30T17:47:06.667607858+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> received lifecycle event: doConfigure
2022-11-30T17:47:06.675732108+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found DeviceLifecycleDispatcher handler in zwave_sensor → fibaro door window sensor
2022-11-30T17:47:06.680277024+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={configuration_value=0, default=false, parameter_number=1, size=1}, cmd_class=“CONFIGURATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x01\x00”, src_channel=0, version=1}
2022-11-30T17:47:06.687708608+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(26e97085) queued for radio transmission: CC:Configuration, CID:0x04
2022-11-30T17:47:06.693512066+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={configuration_value=0, default=false, parameter_number=2, size=1}, cmd_class=“CONFIGURATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x02\x01\x00”, src_channel=0, version=1}
2022-11-30T17:47:06.701223524+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(f3e4f729) queued for radio transmission: CC:Configuration, CID:0x04
2022-11-30T17:47:06.705502358+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={configuration_value=6, default=false, parameter_number=3, size=1}, cmd_class=“CONFIGURATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x03\x01\x06”, src_channel=0, version=1}
2022-11-30T17:47:06.714098608+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(eef7c420) queued for radio transmission: CC:Configuration, CID:0x04
2022-11-30T17:47:06.718302108+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x01”, src_channel=0, version=1}
2022-11-30T17:47:06.725558108+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(973f1833) queued for radio transmission: CC:Association, CID:0x01
2022-11-30T17:47:06.731798899+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found CapabilityCommandDispatcher handler in zwave_sensor → fibaro door window sensor
2022-11-30T17:47:06.734663358+00:00 PRINT Z-Wave Sensor and Child Thermostat Mc <<< Refresh >>>
Reply
[![|45x45](upload://tc3qnElExzu4MfDmPwc7x76MGCa.png)](https://community.smartthings.com/u/makrisn)
[makrisn](https://community.smartthings.com/u/makrisn)
[38m](https://community.smartthings.com/t/post-requests-for-edge-drivers-here-community-created/237327/1158?u=makrisn)
@Mariano_Colmenarejo … part 2
2022-11-30T17:47:06.739713274+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={scale=0, sensor_type=“TEMPERATURE”}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x00”, src_channel=0, version=5}
2022-11-30T17:47:06.746774233+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(ddeb919b) queued for radio transmission: CC:Sensor Multi-level, CID:0x04
2022-11-30T17:47:06.752374858+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={}, cmd_class=“BATTERY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“”, src_channel=0, version=1}
2022-11-30T17:47:06.759324524+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(58e0f85f) queued for radio transmission: CC:Battery, CID:0x02
2022-11-30T17:47:06.766674399+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(0e4536da) transmit status: TRANSMIT_COMPLETE_OK
2022-11-30T17:47:06.768162691+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={sensor_type=“DOOR_WINDOW”}, cmd_class=“SENSOR_BINARY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x0A”, src_channel=0, version=2}
2022-11-30T17:47:06.774874566+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(ead99faf) queued for radio transmission: CC:Sensor Binary, CID:0x02
2022-11-30T17:47:06.778807108+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={sensor_type=“GENERAL_PURPOSE_ALARM”}, cmd_class=“SENSOR_ALARM”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x00”, src_channel=0, version=1}
2022-11-30T17:47:06.786955399+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(a8dbc0fa) queued for radio transmission: CC:Sensor Alarm, CID:0x01
2022-11-30T17:47:06.790985524+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={sensor_type=“TAMPER”}, cmd_class=“SENSOR_BINARY”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x08”, src_channel=0, version=2}
2022-11-30T17:47:06.798097608+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(6bcf4ce5) queued for radio transmission: CC:Sensor Binary, CID:0x02
2022-11-30T17:47:06.801772983+00:00 ERROR Z-Wave Sensor and Child Thermostat Mc Fibaro Open/Closed Sensor thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)>:
arg1: doConfigure
arg2: table: 0xc29e80
arg1: doConfigure
[string “fibaro-door-window-sensor/init.lua”]:108: attempt to index a nil value (global ‘self’)
2022-11-30T17:47:06.811194108+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Fibaro Open/Closed Sensor device thread event handled
2022-11-30T17:47:06.826496524+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(4a83c0ee) transmit status: TRANSMIT_COMPLETE_OK
2022-11-30T17:47:06.860944691+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Received event with handler unnamed
2022-11-30T17:47:06.867536399+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> received Z-Wave command: {args={battery_level=98}, cmd_class=“BATTERY”, cmd_id=“REPORT”, dst_channels={}, encap=“CRC16”, payload=“b”, src_channel=0, version=1}
2022-11-30T17:47:06.875464524+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:06.879162191+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> emitting event: {“attribute_id”:“battery”,“capability_id”:“battery”,“component_id”:“main”,“state”:{“value”:98}}
2022-11-30T17:47:06.888938691+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Fibaro Open/Closed Sensor device thread event handled
2022-11-30T17:47:06.956617733+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(f7cb2ee4) transmit status: TRANSMIT_COMPLETE_OK
2022-11-30T17:47:06.964087691+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Received event with handler unnamed
2022-11-30T17:47:06.969005358+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> received Z-Wave command: {args={sensor_value=“IDLE”}, cmd_class=“SENSOR_BINARY”, cmd_id=“REPORT”, dst_channels={}, encap=“CRC16”, payload=“\x00”, src_channel=0, version=1}
2022-11-30T17:47:07.005191358+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.008358441+00:00 WARN Z-Wave Sensor and Child Thermostat Mc Attempted to generate event for a9710043-7434-4115-876e-568f8f43255a.main but it does not support capability Water Sensor
2022-11-30T17:47:07.011494483+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.014857191+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> emitting event: {“attribute_id”:“contact”,“capability_id”:“contactSensor”,“component_id”:“main”,“state”:{“value”:“closed”}}
2022-11-30T17:47:07.024190024+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.027962399+00:00 WARN Z-Wave Sensor and Child Thermostat Mc Attempted to generate event for a9710043-7434-4115-876e-568f8f43255a.main but it does not support capability Motion Sensor
2022-11-30T17:47:07.031539233+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.049978691+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.054010191+00:00 WARN Z-Wave Sensor and Child Thermostat Mc Attempted to generate event for a9710043-7434-4115-876e-568f8f43255a.main but it does not support capability Temperature Alarm
2022-11-30T17:47:07.057142774+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.060223358+00:00 WARN Z-Wave Sensor and Child Thermostat Mc Attempted to generate event for a9710043-7434-4115-876e-568f8f43255a.main but it does not support capability Smoke Detector
2022-11-30T17:47:07.063423774+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Fibaro Open/Closed Sensor device thread event handled
2022-11-30T17:47:07.086634108+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(db36df4f) transmit status: TRANSMIT_COMPLETE_OK
2022-11-30T17:47:07.094047608+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Received event with handler unnamed
2022-11-30T17:47:07.098261233+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> received Z-Wave command: {args={seconds=0, sensor_state=“NO_ALARM”, sensor_type=“GENERAL_PURPOSE_ALARM”, source_node_id=61}, cmd_class=“SENSOR_ALARM”, cmd_id=“REPORT”, dst_channels={}, encap=“CRC16”, payload=“\x3D\x00\x00\x00\x00”, src_channel=0, version=1}
2022-11-30T17:47:07.147039149+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.150093274+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.153489483+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> emitting event: {“attribute_id”:“contact”,“capability_id”:“contactSensor”,“component_id”:“main”,“state”:{“value”:“closed”}}
2022-11-30T17:47:07.161521066+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.164623566+00:00 WARN Z-Wave Sensor and Child Thermostat Mc Attempted to generate event for a9710043-7434-4115-876e-568f8f43255a.main but it does not support capability Motion Sensor
2022-11-30T17:47:07.167909399+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.170931149+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Fibaro Open/Closed Sensor device thread event handled
2022-11-30T17:47:07.174030483+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Received event with handler device_lifecycle
2022-11-30T17:47:07.187998649+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> received lifecycle event: infoChanged
2022-11-30T17:47:07.201340983+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found DeviceLifecycleDispatcher handler in zwave_sensor → fibaro door window sensor
2022-11-30T17:47:07.206926608+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={configuration_value=6, default=false, parameter_number=3, size=1}, cmd_class=“CONFIGURATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x03\x01\x06”, src_channel=0, version=1}
2022-11-30T17:47:07.214350566+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(02dc31d1) queued for radio transmission: CC:Configuration, CID:0x04
2022-11-30T17:47:07.218159441+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={parameter_number=3}, cmd_class=“CONFIGURATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x03”, src_channel=0, version=1}
2022-11-30T17:47:07.225304566+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(230f8486) queued for radio transmission: CC:Configuration, CID:0x05
2022-11-30T17:47:07.230011358+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={configuration_value=0, default=false, parameter_number=54, size=1}, cmd_class=“CONFIGURATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x36\x01\x00”, src_channel=0, version=1}
2022-11-30T17:47:07.237023608+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(2462ce53) queued for radio transmission: CC:Configuration, CID:0x04
2022-11-30T17:47:07.241220108+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={parameter_number=54}, cmd_class=“CONFIGURATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“6”, src_channel=0, version=1}
2022-11-30T17:47:07.247735066+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(b5644175) queued for radio transmission: CC:Configuration, CID:0x05
2022-11-30T17:47:07.252822233+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={configuration_value=0, default=false, parameter_number=1, size=1}, cmd_class=“CONFIGURATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x01\x01\x00”, src_channel=0, version=1}
2022-11-30T17:47:07.259754649+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(11b1cf58) queued for radio transmission: CC:Configuration, CID:0x04
2022-11-30T17:47:07.263890233+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={parameter_number=1}, cmd_class=“CONFIGURATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x01”, src_channel=0, version=1}
2022-11-30T17:47:07.270459441+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(e98e63d6) queued for radio transmission: CC:Configuration, CID:0x05
2022-11-30T17:47:07.278945983+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={configuration_value=0, default=false, parameter_number=2, size=1}, cmd_class=“CONFIGURATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x02\x01\x00”, src_channel=0, version=1}
2022-11-30T17:47:07.287570274+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(8e7b5031) queued for radio transmission: CC:Configuration, CID:0x04
2022-11-30T17:47:07.291600483+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={parameter_number=2}, cmd_class=“CONFIGURATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x02”, src_channel=0, version=1}
2022-11-30T17:47:07.297663941+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(fb75184f) transmit status: TRANSMIT_COMPLETE_OK
2022-11-30T17:47:07.302253858+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(9701cd82) queued for radio transmission: CC:Configuration, CID:0x05
2022-11-30T17:47:07.306660524+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={configuration_value=1, default=false, parameter_number=31, size=1}, cmd_class=“CONFIGURATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x1F\x01\x01”, src_channel=0, version=1}
2022-11-30T17:47:07.318613858+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(2624b34b) queued for radio transmission: CC:Configuration, CID:0x04
2022-11-30T17:47:07.322662941+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> sending Z-Wave command: {args={parameter_number=31}, cmd_class=“CONFIGURATION”, cmd_id=“GET”, dst_channels={}, encap=“AUTO”, payload=“\x1F”, src_channel=0, version=1}
2022-11-30T17:47:07.329387691+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(ad2dcded) queued for radio transmission: CC:Configuration, CID:0x05
2022-11-30T17:47:07.336506024+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Fibaro Open/Closed Sensor device thread event handled
2022-11-30T17:47:07.340889608+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Received event with handler unnamed
2022-11-30T17:47:07.346059899+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> received Z-Wave command: {args={sensor_value=“IDLE”}, cmd_class=“SENSOR_BINARY”, cmd_id=“REPORT”, dst_channels={}, encap=“CRC16”, payload=“\x00”, src_channel=0, version=1}
2022-11-30T17:47:07.358723483+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.361912858+00:00 WARN Z-Wave Sensor and Child Thermostat Mc Attempted to generate event for a9710043-7434-4115-876e-568f8f43255a.main but it does not support capability Water Sensor
2022-11-30T17:47:07.365215899+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.368590441+00:00 INFO Z-Wave Sensor and Child Thermostat Mc <ZwaveDevice: a9710043-7434-4115-876e-568f8f43255a [3D] (Fibaro Open/Closed Sensor)> emitting event: {“attribute_id”:“contact”,“capability_id”:“contactSensor”,“component_id”:“main”,“state”:{“value”:“closed”}}
2022-11-30T17:47:07.377352941+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.380502733+00:00 WARN Z-Wave Sensor and Child Thermostat Mc Attempted to generate event for a9710043-7434-4115-876e-568f8f43255a.main but it does not support capability Motion Sensor
2022-11-30T17:47:07.384742066+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.388010983+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.391675024+00:00 WARN Z-Wave Sensor and Child Thermostat Mc Attempted to generate event for a9710043-7434-4115-876e-568f8f43255a.main but it does not support capability Temperature Alarm
2022-11-30T17:47:07.395674566+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Found ZwaveDispatcher handler in zwave_sensor
2022-11-30T17:47:07.398760149+00:00 WARN Z-Wave Sensor and Child Thermostat Mc Attempted to generate event for a9710043-7434-4115-876e-568f8f43255a.main but it does not support capability Smoke Detector
2022-11-30T17:47:07.401896941+00:00 DEBUG Z-Wave Sensor and Child Thermostat Mc Fibaro Open/Closed Sensor device thread event handled
2022-11-30T17:47:07.456091149+00:00 TRACE Z-Wave Sensor and Child Thermostat Mc Z-Wave command(26e97085) transmit status: TRANSMIT_COMPLETE_OK
Thanks for moving all the logs to this thread and deleting them from the other.
To focus the matter.
This device does not support the Command Class SENSOR_MULTILEVEL and therefore I do not know how it can send the temperature
Does this device send temperature with the DTH?
What DTH do you use? to take a look
From what I see it must have a firmware 2.5 or lower and it does not support the parameters that control the temperature reports and other reports.
I will look for how I can read the firmware for a zwave device
The closed event is emitted fine, it should work fine for open as well.
thanks again for all your help and guidance @Mariano_Colmenarejo
I was using the custom handler until very recently, was consistenly reporting temperature
maybe something there?
Hi @makrisn
Try with this version.
According to the DTH, it seems that although It does not see, the c.c. multilevel sensor sends temperature through endpoint 2.
I have modified the driver, to see if it sends temperature through endpoint 2
 Name         Z-Wave Sensor and Child Thermostat Mc
 Version      2022-11-30T20:40:55.318818535
If you capture more logs, enter the number corresponding to this driver that shows you on the screen in the CLI.
This way it will only show the logs of this driver
It works! It now reports the temperature (and the contact sensor too).
You are a magician. Thank you so much for your help (and patience). Will continue to monitor it, so far, so good!
Cheers
@makrisn
I’m glad it works!
I need your help to make these devices work better for you and other users.
Although they are the same 0700 model they have very different firmware which makes them work differently as well.
The way to differentiate and configure them correctly is to read the firmware, so I have put a code in the driver to read the firmware version.
You could install it, perform a refresh on the device and capture the logs
 Version      2022-12-01T12:24:49.577339513
@makrisn
Please remove the format </> to logs
The device did not respond as expected.
I have put another impression to see if I capture firmware version.
Just install this version with the CLI command smartthings edge:drivers:install
Then capture the logs when you run the refresh in the App
 Version      2022-12-01T13:56:30.816347126
@makrisn
Right after the latter should be the response from the device to the firmware version of the refresh.
There’s no more after this?
And if You want can delete last three logs
Ok, thanks
your device is a old firmware version 2.5.
The new version for model 0700 is 3.2
I’ll look to see if I make some specific profiles for this firmware.
Are you going to use temperature on the mosaic?
I’ll let you know when it’s done.
It will take me a few days to do it.
