Ok,
Then the drivers need a optional profile change to temperature profile.
Smartthings will not do It!
When i can i will modify the driver stock and Iβll let you know
Ok,
Thank you very much for helping. So Iβm waiting for you thanks again
Hi @alefavara
I have modified the stock Z-wave Sensor driver:
- name: "operationMode"
title: "Sensor Operation Mode"
description: "Defines Door/Window Sensor or external alarm sensor or external Button.(default: Door/window Sensor or Ext.Alarm)"
required: false
preferenceType: enumeration
definition:
options:
0 : "Door/window Sensor or Ext.Alarm"
1 : "External Button"
default: 0
preferences:
- name: "useExtTempSensor"
title: "Use External Temp Sensor"
description: "Use External Temperature Sensor"
required: false
preferenceType: boolean
definition:
default: false
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Z-Wave Sensor Mc
Version 2022-09-26T22:09:46.653637754
Please, try and tell me if works fine
Please post logs like this using the coding tag </>.
It makes long lines and list much easier to read and doesn't clog up the community. It makes long lines and list much easier to read and doesn't clog up the community. It makes long lines and list much easier to read and doesn't clog up the community.
Hello,
I have Roller Shutter 2 (FGR-222): fingerprint 010f/0301/1001. With Edge Driver I should instal: Z-Wave Switch Mc or Z-Wave Window Treatment Mc ?
Marcin, both will work, but for the Roller Shutter, Z-Wave Window Treatment Mc would be better suited I think.
Hi @Paul_Oliver
Try with this driver version to see if works fine without childs option.
If works fine then i will see if can implement childs option in the subdriver with your help
Name Z-Wave Switch and Childs Mc
Version 2022-09-27T12:57:58.142111067
I prefer the logs without the </> option, Iβm used to seeing it like this in the CLI changing lines without having to scroll to see the entire line
I switched to your new driver and after switching between the stock driver and your new driver switch #2 is functional but there still is no setting menu.
Operation is not consistent. Some times I push Main switch and everything works as expected, something switch 1 doesnβt work, sometimes switch 2 doesnβt work and some times I get a network error.
So it is much improved but not there yet. I am not currently home. In a couple hours went I get home I can get you some logs if desired.
Thanks for your help.
With stock Z-Wave Switch driver works fine?
I do not activate the Child menΓΊ settings yet
Yes, stock Z-Wave driver works fine. That is what I was using.
this version has the exactly same subdriver stock
Version 2022-09-27T11:26:39.036523141
I did as you said but it doesnβt work it doesnβt display anything and the open or closed state doesnβt work either
Yes, this is the correct version, sorry
Have you entered in device settings and selected the external temperature profile and cleared the appβs cache?
If it does, the temperature capability should appear even if it also has a cloud
In your screenshoots with Z-wave Sensor stock driver the tamper alert not works either
Did you exclude device and pair again or did you do a driver change?
You should exclude it and include it again
No, I didnβt, because I was not home. I am home now and will exclude and repair.
Yes, I deleted and reinstalled the device.
As you can see now the temperature option appears to me even if it is not yet seen. Then the open and closed state does not work.
And then as you can see in the picture is it possible to have an option and directly see the temperature in the button? Iβll explain I am using this sensor not for opening and closing the window but to control the water temperature of an aquarium
