│ Name │ Zigbee Light Multifunction Mc │
│ Version │ 2022-06-17T18:59:44.964821147 │
Driver Zigbee Light Multifunction Mc Updated the presentations of the Custom Capabilities with the alternative values for the state button and I have changed the displayType:ToggleSwitch for displayType:switch, which seems more appropriate, leaving the power button only for on and off.
The driver version is the same and the presentations will be updated when clearing the cache in android and when reopening the app and each device once or twice and it will show the new switch buttons.
│ Version │ 2022-06-26T20:24:06.570181871 │
I have 2 Lidl RGBW bulbs and they work fine.
It may be the problem with the refresh of the app.
Try to clear the cache of the app or if it does not solve it, have a reboot of the Hub from IDE
@Kristian_Horup
It may be the problem of the app, if the capablitity is not initialized with a value.
Try setting a value to those capabilities with an automation and it will resolve.
This date version of driver fix the problem with new app version and capabilities without value assigned.
│ Version │ 2022-06-27T11:06:51.719654002 │
I have an issue with a zigbee led strip controller device you added into an edge driver for me a while back. Sorry if this has already been addressed.
GLEDOPTO ZigBee LED Strip Controller RGBww/cw
I have 3 of these with the same issue.
Driver: Zigbee Light Multifunction Mc Ver-2022-06-27
Issue: If dimming action is made from an automation in either WW/CW, the dimming action is hit or miss. Example: If lights are at 20% brightness, and an automation calls for 100%, the lights may or may not set to 100%. What usually happens is they will flash to 100% then return to 20%.
Strange thing is tho, if I make dimming changes from the ST app, or Alexa, the lights respond perfectly.
I have double checked my automations to make sure there’s no duplicate commands.
I have not been able to reproduce the problem.
I’ve tried various automations with two different devices, setting a new level with different previous levels, and turning the device from on and off.
How exactly is your routine?
Is the device On or Off before automation set?
Do you have progressive On or Off activated?
Do you have set transition times > 0 for level or On-Off in preferences?
In the routine, does only the level change or also the Activated command?
If you send only the level, the driver will take care of turning on the bulb if it is off.
I also have problems with the ledavance gu10 rgbw. The light is not as stable as before.
When using the app on the specifik light it works perfectly with a little delay. But when I use routines either in trendsetter or a button there are problems with dimming, color, and deactivating.If I have more light in a group with same routine some lights works seperatly than the rest, som do not react.
They work also slower in a routine. They respond with a lot off delay and popcorn effect.
I really find your driver good but something s is not right.
i have tried to turn the hub on/off with no result. Reset the bulbs with same result.
I have Lidl bulb as well, but have not examined if they have problems.
The driver hasn’t changed for some time, only to emit a value in the capabilities initialization on installation, due to changes in the app.
What is changing daily is the app or the add-ons.
Also the operation of the zigbee and zwave networks of the hub are dynamic and change continuously and in these moments of installing and uninstalling drivers, DTHs, devices… the networks are continually reconfigured and they do not always do it correctly at the first attempt.
I believe that those problems that all or most of us are and are suffering is due to the moment of continuous changes in smartthings that we have to live.
I’m using IKEA Trådfri bulbs and maximum color temperature I can choose is 4 000K. Before with the IKEA driver I could choose up to 6 500K. How comes that I can’t select higher than 4 000K?
I was looking for a way to set color temperature and brightness throughout the day, regardless of when lamps are switched on or off. And I suppose this driver does the trick, without me having to do different automations for each bulb whenever color temperature and brightness is supposed to change. Thanks for that!!
