I noticed that after upgrading to the Hue Hub V2 that some of my commands from apps don’t work. I am talking about the new Hue hub that is square and supports HomeKit, not the V2 SmartThings hub, which I also have.
Here’s a few errors from the logs of the Hue Bridge. Is there an update of some sort, I don’t seem to be able to edit the code for the Hue Bridge under “My Devices”
error groovy.json.JsonException: Expected a value on line: 1, column: 2.
error groovy.json.JsonException: Expected a closing curly brace '}' or a comma ',' on line: 1, column: 90.
error groovy.json.JsonException: Expected a closing curly brace '}' or a comma ',' on line: 1, column: 145.
Hi Patrick,
Thanks for the heads up!
I requested a bridge V2 to run some tests but if find something in the code that can be improved please post it and mention me and I will get it published.
Thanks a lot!
I had an even worse issue. I got the new hue hub and got the migration done it worked fine with smart things. Then I got the new smart things up and redid everything and hue worked fine. I added a bulb and it worked well. I tried adding a bulb and I got the error it could not save plumb list (can’t remember exactly) but I had a bunch more to add the next day so I did not worry about it. I uninstalled all hue bulbs and hub as I was redoing almost every light then when done smartthings found the hub as usual found the bulbs but when I hit done got the same message that the list could not be saved. well a little research told me tp reboot the hue hub did not help reboot smartthigns did not help but now I can’t open the hue smart app. nothing happens I can’t choose add new phillips light nothing happens. three different phones one a android and nope rebooted everything nope. reset the router nope. though hue had a update yesterday and great smartthings found it but again would not save the bulb list. I rebooted again and now back to no able to open the smart app. Pdf course when I emailed smartthings I listed all I did I even included the weblink and they asked me to do all the things. sorry I can’t do them because I can’t open the smart app.
