New Hub (V3), can not add any of my appliances to the 'SmartThings' App
All, I am new to the group. I just purchased a new Hub (V3) and I can not add any of my appliances to the ‘SmartThings’ App. I get all the way to “Your Washer is being registerd to your Samsung account” and then it times out. I have all the Samsung appliances (Washer/Dryer/Frig, etc…) None of them will join the app, same results.
A bit more information:
I have Cisco network at home. All APs are in the same VLAN as the Hub. I am running my DHCP with the Cisco Router:
ip dhcp excluded-address 172.16.3.1 172.16.3.30
ip dhcp pool vlan30pool
import all
network 172.16.3.0 255.255.255.0
default-router 172.16.3.1
ip domain name honeypot.com
ip name-server 8.8.8.8
interface FastEthernet0
description ISP INTERFACE
ip address dhcp
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0
switchport trunk native vlan 10
switchport mode trunk
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet5
switchport access vlan 30
no ip address
interface Vlan30
description SECURED
ip address 172.16.3.1 255.255.255.0
ip nat inside
As mentioned, this was working, well the frig was working. Thus, why I upgraded to a newer Hub.
One more thing, when I check the logs in the router/DHCP server, I see:
HOUSE_SWR_00#
*Jan 3 14:31:55.014: DHCPD: client’s VPN is .
*Jan 3 14:31:55.014: DHCPD: No option 125
*Jan 3 14:31:55.014: DHCPD: DHCPREQUEST received from client 018c.861e.df24.d5.
*Jan 3 14:31:55.014: DHCPD: Option 125 not present in the msg.
*Jan 3 14:31:55.014: DHCPD: Appending system default domain
*Jan 3 14:31:55.014: DHCPD: Using hostname ‘Colbys-iPhone.honeypot.com.’ for dynamic update (from hostname option)
*Jan 3 14:31:55.014: DHCPD: Sending DHCPACK to client 018c.861e.df24.d5 (172.16.3.40).DHCPD: Setting only requested parameters
*Jan 3 14:31:55.014: DHCPD: no option 125
*Jan 3 14:31:55.014: DHCPD: src nbma addr as zero
*Jan 3 14:31:55.014: DHCPD: ARP entry exists (172.16.3.40, 8c86.1edf.24d5).
*Jan 3 14:31:55.014: DHCPD: unicasting BOOTREPLY to client 8c86.1edf.24d5 (172.16.3.40).
HOUSE_SWR_00#
YES I do have a firewall, all trafic is allowed out, I see no drops or deny packets.
Please Help!
