Yep, that fixed it
A noobisch question, I just want to turn on and of two different lamps with de FSG-223. Ive installed everything and with the app I can turn off and on both lights. Iām using a momentary dual switch and the first lamp is connected to S1 and the second one to S2. The S1 lamp is working fine but the S2 is not reacting on the switch.
What should be the paramaters for this config? Iām lost!
Arjan - I have two of the FGS-223 modules one connected with momentary and
one connected with toggle switches. The both work well
The Momentary settings are
First 9 settings are as per the Defaults
Switch type is Momentary
Power reports as per Defaults
Scene IDās I just use the Double press the others are off.
Personally I think if the lamp works from the software but not the switch
it is most likely a hardware problem. Check it is wired correctly.
Jon
Jon Eskdale
07530 112233
Skype āeskdaleā
Aaarghhhā¦ you were right! I ment the lamps were connected to Q1 and Q2. De switches were connected to S1 an S2. But thanks to you I saw that I forget to connect the seccond switch two the COM .
Everything works now!!
Thnx!
Hello how are you?
I am new to this and I am very keen to use this double relay switch to save space and money. However I am new to smartthings and do not know what a handler is and do not know where to start. I have been experimenting for a few months now and understand the general concept and all, but need to learn how to add this double relay switch. Can you help?
A simple, I hope, question about the Fibaro Switch.
I have one of these working and Iām using it to turn on a Bathroom fan.
Working brilliantly turning it off and on with humidity levels.
Itās a ver 2.02 and the DH is Z-Wave Device Multichannel.
When it turns on and off, the state updates immediately in the ST app on my phone.
I have just installed another one which is a ver 3.02. and is using the same DH. When it turns on and off, it does not update its state in the app.
I also see more information for the newer switch in the recently tab. It does say turning on and turning off, but this is not reflected in the app state.
Is anyone else out there using the newer switch version?
What DH are you using?
Are you getting the same issue as me?
Here is what I see in the ide for the ver. 2.02.
Here is what I see for the ver. 3.02.
Also flagging up to the Fibaro guru @anon36505037 as I know you use these extensively. Hope you donāt mind.
Must admit I havenāt. As the ver 2.02 was working well using the stock handler I assumed this would be good on the ver 3.02 as well.
Will give it a shot.
Thanks for the prompt response.
Hi Robin.
Apologies for not getting back sooner.
Changed to the DH as you suggested and it works like a dream.
Thanks again.
Iām having a problem with the 223, in that it seems to work perfectly for a few days, then suddenly S1 will get stuck in the āonā position, and neither the app nor the physical switch will turn off the lamp. Wierdly, changing the physical switch updates the app, the power drops to 0w, everything looks as though it should be working, fine, but the relay doesnāt make the usual āclickā noise and the lamp doesnāt turn off.
Any ideas what I can do to debug this?
So interesting. I had this exact thing happen to a Qubino Dual Relay a week or so ago. It would not turn off unless I killed power from the circuit breaker. I thought it a faulty device so replaced it with an enerwave. To my surprise the enerwave started doing it too! I then replaced the physical switch (it was worth a shot) . . . same problem. The whole time I am double, triple checking my wiring. I tried another Enerwave that I had lying around and it did the same thing as well. I am absolutely dumbfounded by this and eventually reverted the switch to a non-smart switch as I couldnāt have it on 24x7.
I really have no idea what is going on.
How wierd! Just as a shot, I tried swapping the channels, and it does seem to have stabilised yesterday but Iāll keep an eye on it and let you know.
Just out of interest do you have any zwave associations set on the device?
Regards,
Paul Needler
Helloooo.
Iām italian and I donāt speak perfect english.
I have a V2 Hub and I would add some Fibaro switches for lights and roller shutter.
I read about some problems.
Can someone help me?
Thank you.
Marco
What kind of problems are you referring to?
Compatibily problems between Smartthings Hub (I have V2) and Fibaro products.
For example, yesterday I add my first Fibaro sensor (motion sensor). I have it in my hand, not on the wall. And in the Smartthings app says it is ātamperedā.
I connect it for two times and I create an automation (notify me whenā¦).
I read all Fibaro switch for lights and rollers shutter have problems to connect to the Hub.
Is it correct or no?
I have not had any problems connecting Fibaro devices to SmartThings. I havenāt had any problems with functionality either.
Ok. In this discussion I read some problems at first.
So I need only to find the dimmer on the app and all works?
I have had zero problem with my Fibaro modules. In fact they are the most reliable part of my system. I had one minor issue with the Fibaro smoke detector that Smarthings fixed with an update.
Ok.
In this topic I read some people has problems and they set Hub in a mode for work with Fibaro.
Probably it was an old problem.
Iām sorry I donāt speak a good englishā¦
