Can I control the dual outputs individually?
When I use Dim and Dimmer smart app or Routines I can only seem to control the unit as a whole, and I guess turn both outputs on or off simultaneously?
Just updated all my handlers to the new color scheme.
Thanks, Iāll give that a go.
@erocm1231 back in December it looks like you were having discussions with Fibaro about getting double and triple clicks to work. From using your DH today I can see it is only sending a sceneid of 1 or 2. Did you ever get this worked out, how to get sceneid sent correctly?
Thanks in advance.
Roger
(Brand new forum user)
Honestly, I donāt believe this functionality made it into the switch. Unless there is some hidden configuration that isnāt documented, the feature just doesnāt work. It is unlike the Dimmer 2 (which does have this feature working) in the way that it doesnāt āhesitateā when doing a double, triple toggle etc.
Thanks for coming back to me Eric. I might ping over in the Fibaro forums and ask if anyone using these devices are able to use the feature through Home Centre.
Late here for me now, spent a lot of time this evening understanding how device handlers work and it is past midnight now. So Iāll dig further tomorrow. If I find anything (which I know is unlikely) Iāll give a go updating the DH and let you know.
By the way, is there a way to discover if there any undocumented parameters available on the switch, like doing some sort of iteration round all numbers from 1 to 100 or getting doing a bulk report?
Pretty sure the sceneid is stored in keyAttributes property of $cmd, at least that is where other controllers are getting it from. Or it may be without the āsā. I see someone has written a DH for the Fibaro Button with an āsā, and other controllers accessing the FGS-223 value with an āsā. Links below are examples from research.
@erocm1231 Iāve done some testing this evening. āsceneNumberā holds the switch clicked. ākeyAttributesā holds the scene number.
I get this type of event:-
2017-03-30 7:04:01.628 PM BST
8 minutes ago DEVICE button 1x click Living Room Light Switch button 2 was 1x click
I havenāt checked values for Toggle Switch, but my code for momentary is as below:
switch (cmd.keyAttributes) {
case 0: // 1x click
buttonEvent(cmd.sceneNumber, ā1x clickā)
break
case 1: // 1x click
buttonEvent(cmd.sceneNumber, āreleasedā)
break
case 2: // 1x click
buttonEvent(cmd.sceneNumber, āheldā)
break
case 3: // 1x click
buttonEvent(cmd.sceneNumber, ā2x clickā)
break
case 4: // 1x click
buttonEvent(cmd.sceneNumber, ā3x clickā)
break
default:
logging(āUnhandled SceneActivationSet: ${cmd}ā)
break
Heavily ripped off (from Eric) but modified DH here. Not sure how to get my repo setup properly to work with SmartThings (something to look at)
Edited: removed link to my modified DH
If it is just a matter of keyAttribute vs sceneNumber, I would rather just update my handler so their arenāt multiple versions floating around. I do appreciate you looking into it though. The problem I was having is that no matter what type of toggle I attempted at the switch, it would report the same CentralScene information. In addition, when doing a 2x click, the light would flip on and off and 1 3x click on/off/on. This is not the same behavior as the Dimmer 2 which if you do a 2x click, the attached light is not affected. To me, the Dimmer 2 behavior makes more sense and indicated that the Double switch was not behaving properly.
I will test the CentralScene info when I get home to see if there is something I missed.
Eric, Iām happy to remove my DH so there is no fork. What I was seeing at scenenumber reflected which button clicked, keyattributes reflects how many times clicked, which fired twice with value 1 and 2 if you do a hold and release. You are right that it always switches load, which is not what you want. Iām trying to replace a standard uk double dimmer, so need to support two loads, which the dimmer doesnāt do.
Iāll investigate further.
Hi Robin, not trying to create a fork, so Iāll remove from Git. Have absolutely no intention of taking credit from Eric, but wasnāt sure on the right etiquette. Need to learn how to do a pull request to Ericās repo if that is the right terminology.
Iāll have a go when family are gone to bed
edit: but as you say, I think that is 2-5 association groups
Thanks @RogerSelwyn for pointing out something that I missed on the scene processing. It is now working with the following mappings. On the right is the action you take on the switch and on the left is what will be usable in SmartThings.
Button Mappings
Toggle Mode
1 pushed - S1 1x toggle
4 pushed - S1 2x toggle
5 pushed - S1 3x toggle
1 held - S2 1x toggle
4 held - S2 2x toggle
5 held - S2 3x toggle
Momentary Mode
1 pushed - S1 1x click
2 pushed - S1 release
3 pushed - S1 hold
4 pushed - S1 2x click
5 pushed - S1 3x click
1 held - S2 1x click
2 held - S2 release
3 held - S2 hold
4 held - S2 2x click
5 held - S2 3x click
Thanks @erocm1231. The help doesnāt show for me on the device. I donāt know if you need the paragraph formatting to be
title:"${it.@label}\n" + "${it.Help}"
Iām on iOS. Not quite sure what you mean by initial settings paragraph.
If you mean the āOnce you changeā¦ā text, yes I get that under a title called Settings.
Alright, I believe I have it fixed for iOS. Let me know if you notice anything else.
