c86e77f0-c7cf-4664-8e3f-468e09d982eb 08:29:07: debug Parsed SecurityMessageEncapsulation(commandByte: [4, 5, 0, 1], commandClassIdentifier: 133, commandIdentifier: 3, reserved13: 0, secondFrame: false, sequenceCounter: 0, sequenced: false) to [1]
c86e77f0-c7cf-4664-8e3f-468e09d982eb 08:29:07: debug AssociationReport AssociationReport(groupingIdentifier: 4, maxNodesSupported: 5, nodeId: [1], reportsToFollow: 0)
c86e77f0-c7cf-4664-8e3f-468e09d982eb 08:29:07: debug Setting association group 4
c86e77f0-c7cf-4664-8e3f-468e09d982eb 08:29:07: debug Configuring Device For SmartThings Use
Here is the output of the physical switches being turned on and off once each.
6aabb3b5-752e-4a7d-9a0b-be0ed10ef166 08:36:37: debug powerHandler called with event: name:power1 source:DEVICE value:0.0 isStateChange: true isPhysical: false isDigital: false data: {“microDeviceTile”:{“type”:“value”,“label”:“0.0 W”,“backgroundColor”:"#ffffff"}} device: T - Lounge and Dining Main
6aabb3b5-752e-4a7d-9a0b-be0ed10ef166 08:36:36: debug physicalHandler called with event: name:switch1 source:DEVICE value:off isStateChange: true isPhysical: false isDigital: false data: {“microDeviceTile”:{“type”:“standard”,“icon”:“st.switches.switch.off”,“backgroundColor”:"#ffffff"}} device: T - Lounge and Dining Main
6aabb3b5-752e-4a7d-9a0b-be0ed10ef166 08:36:33: debug physicalHandler called with event: name:switch2 source:DEVICE value:off isStateChange: true isPhysical: false isDigital: false data: {“microDeviceTile”:{“type”:“standard”,“icon”:“st.switches.switch.off”,“backgroundColor”:"#ffffff"}} device: T - Lounge and Dining Main
6aabb3b5-752e-4a7d-9a0b-be0ed10ef166 08:36:32: debug powerHandler called with event: name:power1 source:DEVICE value:157.8 isStateChange: true isPhysical: false isDigital: false data: {“microDeviceTile”:{“type”:“value”,“label”:“157.8 W”,“backgroundColor”:"#ffffff"}} device: T - Lounge and Dining Main
6aabb3b5-752e-4a7d-9a0b-be0ed10ef166 08:36:29: debug physicalHandler called with event: name:switch1 source:DEVICE value:on isStateChange: true isPhysical: false isDigital: false data: {“microDeviceTile”:{“type”:“standard”,“icon”:“st.switches.switch.on”,“backgroundColor”:"#79b821"}} device: T - Lounge and Dining Main
6aabb3b5-752e-4a7d-9a0b-be0ed10ef166 08:36:25: debug physicalHandler called with event: name:switch2 source:DEVICE value:on isStateChange: true isPhysical: false isDigital: false data: {“microDeviceTile”:{“type”:“standard”,“icon”:“st.switches.switch.on”,“backgroundColor”:"#79b821"}} device: T - Lounge and Dining Main
It seems to be working better now. The one oddity I had was that on one occasion turning off the physical switch for S1 did NOT update the mobile app. the tile was still showing greed. Unfortunately I don’t have a log for when that happened.
So it looks like group 4 was the trick. At least it looks like it from glancing at your logs. That is strange about switch1, but hopefully it was just a fluke. Try this out for a bit and let me know how it goes.
@anon36505037 thanks for your answer, I’ve tried the flash mode as you said it turn on/off the light as an alarm. But I need a different behaviour. I have a momentary switch connected to an electrical relay, once pressed it turns the light on, pressing it again turns the light off. How do I have to configure the switch?
I think it already has a small box/circuit that toggles the light on/off
with a momentary push switch. If that is correct he can do away with that
box/circuit because the Fibaro switches have that functionality built in.
Just connect the physical push switch to the Fibaro and the Fibaro to the
light and select the correct mode of operation on the Fibaro.
Select the correct mode of operation on the Fibaro
Yep, is exactly about it!
I need configuration info for those params:
Operating mode: Standard, Delay ON/OFF, Auto ON/OFF, Flashing (maybe not the last one because flashing acts like a siren)
Reaction for Delay/Auto: Cancel, No Reaction, Reset
Time for Delay/Auto: 0-32000
Pulse time for Flashing: 1 - 32000
I tried some combinations, but without any success. Also the official documentation doesn’t help me too much…
@anon36505037 a momentary switch is like a button, does not have the on state and the off state. When I push it for the first time turns on lights, pushing it again turns them off.
I need a push and a release of the button, default configuration works like an on/off toggle. I know that is possibile to configure it to just push but I don’t know how to set the params.
It works! Thanks for your support @anon36505037! I’m agree with yo, about to control a dumb relay with a smart one, I will change the implant when ($$) possibile.
For a momentary switch using the @erocm1231’s “fibaro-fgs-223-dual-relay” I put:
Param 10: 4 (Auto OFF)
Param 12: 1 (0,1s Time for Delay)
And it works. Of course the state of the light is not recognized by the App but I can use both manual and smart switches.
Cheers to all for support
PS. @erocm1231 Auto OFF doesn’t update the icon status in app.
I’m struggling to get my Smartthings to see my FGS-223. Being new to this I guess I am missing something. Can someone give me or point me to a step by step guide to installing this?
Press the ‘B’ button on the front of the module 3 times in quick succession to put it into “Inclusion” mode.
Save the module when it appears.
Go into the “My device Handlers” section of the developer portal and add the FGS-223 device handler.
Go into the “My Devices” section of the developer portal and change the device type for your switch to “Fibaro FGS-223 Dual Relay”.
You could add the device handler first and then it may pick up the correct device type automatically. I think mine did this, but its been a few weeks since I did it so I don’t fully recall.
