Hi,
I was using the following code to generate charts on my device handler. The “dl” variable is an array with 192 integer elements. Recently I started getting the following error when the chart is called in DTH refresh function (periodically)
Does anybody know what does this error mean ?
javax.net.ssl.SSLException: java.security.ProviderException: java.security.InvalidKeyException: EC parameters error @line 1674 (genGraph)
here is the code which calls the chart :
def genGraph()
log.debug "genGraph"
def dl ="t:"
def ul ="t:"
def tt ="t:"
for (int i = 0; i < 191; i++){
dl = dl + state.listdl[i] + ","
dl = dl + state.listdl[191] + "|"
dl = dl + state.listul[i] + ","
dl = dl + state.listul[191]
def maxx = Math.round(state.listdl.max())
def maxx2 = Math.round(state.listul.max())
if (maxx2 > maxx) {maxx=maxx2}
def aralik = maxx/5
def podParams = [
uri: "https://chart.googleapis.com",
//uri: "https://image-charts.com",
path: "/chart",
query: [cht: "lc", chd: dl, chs: "400x250", chof: "gif", chxt: "x,y", chxl: "0:|-12hr|-8hr|-4hr|now", chco: "00FF00,0000FF", chtt: "Traffic", chts:"AAAAAA,15", chxr:"0,0,192,1|1,0,"+maxx+","+aralik, ],
contentType: 'image/gif'
httpGet(podParams) { resp ->
//log.debug resp.data
saveImage(resp.data)
//log.debug "Created new graph"
genGraphx()
btw, when I use “https://chart.googleapis.com” instead of image-charts.com , there is no problem.
Btw, there is one other user who has similar problem recently. Please check the discussion here:
