I ordered 3 ZRC-90 remotes and ofc i missed this post and added it using old DTH method which never worked and are very complicated, my ftrst remote kind of screwed and i could not figure out how to reset it, but as soon as i added fresh out of box 2nd and 3rd remote everything installed correctly and as expected, all buttons working and response time about 0.5 seconds. Thanks !
I tried device reset and exclusion from wave network multiple times for this specific device. I believe itβs some type of fingerprinting inside ST hub itself. Hub memorizing unique device ID and keep adding it the same way without edge driver
Thank you. Anyplace where the correct info is available now?
Also, any idea if the sengled zigbee smart switch has an edge driver? Canβt find any reference to it
I have Enrolled this driver and tried to Add a new ZRC-90.
It came in with the previous NonEdge Device Handler [erocm123 : Remotec ZRC-90 Scene Master]
1 How do I remove it from the Hub (ie do I need to exclude it somehow)? and
2 Do I have to remove the Older DTH first
This would be an issue as I want to get this one on Edge so I can add it into the Routines before I remove my older DTH unit.
If you just comment out the fingerprint in the DTH then older devices using that DTH will still work, but any new device you add will use the Edge Driver instead.
I have installed this driver and added the zrc-90. There are, however, several issues.
1 pressing any of the 8 buttons only cause the βmainβ button to light in the driver screen.
2 setting a routine on any button 1-8 therefore does nothing.
3 if I set a routine for the βmainβ button, pressing any button 1-8 will operate that routine
4 so there are in effect 8 of the same button.
5 also I see that each button can have multiple presses as well as mutiple ToggleUps and multiple ToggleDowns - what is the relevance of this for a zrc-90 which simply has 8 buttons?
PS each button shows
Pressed
Double pressed
Held
Pressed 2, 3, 4, 5, 6 times
Toggled Down and toggled Down 2, 3, 4, 5, 6 times, & Held Down
Toggled Up and toggled Up 2, 3, 4, 5, 6 times, & Held Up
This is the same for all 3 zrc-90s I have attached
Driver is βZ-Wave Button Mcβ
This worked fine, I donβt know why it doesnβt work for you
Try this version of the driver
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Z-Wave Button Mc
Version 2022-10-27T11:45:13.716185987
Today the driver shown in ST matched the new one.
Still displayed same behaviour.
Force zwave removed one zrc-90 and Scanned nearby again and still get exactly same behaviour as my last post.
Itβs strange, no one else has complained about these devices
Please, could you switch to the Z-Wave Thing Mc driver to send me the fingerprints? it could be that it is a different model and or it is configured well
Have removed the Zwave Button Mc driver and installed the Z-Wave Thing Mc driver.
From the IDE I get :
Raw Description zw:S type:0106 mfr:5254 prod:0002 model:8510 ver:1.01 zwv:4.05 lib:02 cc:5E,85,72,21,84,86,80,73,59,5A,5B ccOut:84,5B
It may be different model variant as I am in Australia!?
Version 2022-10-29T09:42:59.036484979
