New capability Temperature Alarm
@Jim
I was creating a new device handler when I came across this capability in the IDE
“Temperature Alarm”
I couldn’t find it in the documentation, is this something new?
What are its Attributes and Commands?
I guess that’s hard to tell without a sample DTH (or docs).
Attributes: temperatureAlarm
My guess? (Boy I love guessing today!):
This is yet another Capability introduced for the ADT Integration. A few others were discovered and are discussed in the ADT Topic. None of them are documented, despite requests to @Jim.
A Temperature Alarm would be used by the ADT SmartApp as an indication of Fire, freezing pipes, or some other condition they’d like to handle with professional monitoring.
(Otherwise, this as a Capability doesn’t make much sense; since Capability Temperature + a configurable SmartApp can easily perform the same function.)
Would be nice if the states were known, we’re working on a freeze sensor so if this attribute can be used for Freeze alerts awesome! @Jim
RBoy
I am running your DH for the aeon WPRIZ-1 motion.temp sensor
(Monoprice and Linear/GoControl WAPIRZ-1 Motion and Temperature Sensor)
and have it installed in a freezer (it was a spare sensor that would report temp).
Can a temp alarm over /under a set temp be added or is there a DH or SA that will accomplish this?
You will need a SmartApp for this. You can create a rule in Smart Home Monitor under Custom Rules. Select temperature monitor and define the rule.
