All time-based routines are now executing an hour late since November 1. This is happening in Alberta, Canada where we have gotten rid of the DST (subtract an hour) transition, which would have occurred on November 1. This has resulted with a new time zone. SmartThings appears not to have updated their database. I can’t manually update the time zone without changing my home location. Has anyone found a workaround to this?
SmartThings (Samsung) has told me this is a problem on their backend servers and they will fix it. Although, they wouldn’t tell me when. The only workaround is to set you time based triggers an hour earlier ![]()
Use @Mariano_Colmenarejo 's virtual calendar and you can select any offset to GMT that your want.
Thanks for your suggestion! Most of my time based automations aren’t directly related to sunrise and sunset so I’m not sure if this will work for me but for the ones that are this is very interesting.
That might not fix your problem for automations with fixed times.
