apparently August is adding support for their entire lineup of locks. But I still only see the Pro in the SmartThings app.
https://august.com/blogs/home/introducing-our-newest-integration-august-smartthings
edit: ah, it says coming by CES 2020
Thatâs good news!
it says coming by CES 2020 , 2021 âŠ2025
Alfred (door lock) has been added
POWERbot-E has been added (robot vacuum)
Very strange. It looks like itâs a Samsung robot vacuum, but very strange that itâs broken out into its own brand and even has its own app that was released in 2019!
POWERbot is Samsungâs robot vacuum line.
right, but there is a whole section at the top for Robot Vacuum under the Samsung brand. Thatâs how I added my R7040. And itâs also strange there is a whole separate app when Samsung has been consolidating under SmartThings since 2017.
Just to update you, my Meross devices now appear within ST after rerunning authentication through the integration!
Thanks! I just did the same thing and itâs working now. Thanks for the heads up.
I tried adding Tailwind to the ST app, but it never opened the door after successfully linking it. I removed it, then tried to re-add it, but it never asks for the login info again, and only shows âsuccessfully connected to Tailwindâ with the Done button. It also doesnât reappear in the ST app. Iâm not sure how to fix this, since it appears to still have the info saved somewhere and it doesnât show up under IDE site. The ST Classic app not working with it also looks like it maybe a pain tying it into automations.
If you installed it through the new app, I doubt it will work in the Classic app. So try it from the new app to see if it works there. If you do need to remove it, go to the side menu (using the three bars in the upper left of the screen), then open settings (the cog) and select Connected Services. You can swipe left on the app name to remove the connection. Connected services is where you find all cloud-to-cloud integrations in the new app. Hope this helps!
That was where I needed to remove it. Removing the device didnât really do it correctly since it was still linked under connected services.
Still confused what exactly is linked with SmartThings though. When I click to open it, it just sits there saying it is opening, but nothing happens. I still need to go to the Tailwind app to open or close it. It does show if it is open or closed correctly, unless I click on it in ST app, where it will just hang saying âopeningâ or âclosingâ.
The ST Classic app would allow me to integrate it with the Security system, so it would disarm it when opened, just like how my Schlage locks can disarm the alarm when unlocked in the ST Classic app. As far as I can tell, there really isnât much integration I can tell at this point.
Any ideas?
Iâd contact tailwind. They own the integration. If itâs showing open/close in the new app, you could probably use it to disarm SmartThings Home Monitor in the new app.
Problem is the new app canât do nearly as much as the classic app, and the smart home monitor on classic app doesnât carry over to the smart home monitor on new app. Most devices, if they restrict usage, restrict it to classic app because of the new app not allowing everything.
Tailwind wonât work properly with the Classic app. So you may not have a choice. The new app can now do 90% of what Classic can, plus other new features that Classic never had.
What do you mean by that it wonât work properly with the classic app? First device Iâve ever seen do that. As for the new app vs. old, the classic app as far more robust automations with it. Until the new app incorporates those I donât see how it is in any way ready to go. Honestly, Iâm not even sure why they canât get those automatons on there yet.
Have you tried the new app in the past two weeks? The most recent update has made quite a few improvements.
Past couple of days. Doesnât seem like anything in terms of automations have improved or matched the classic app. Are Routines showing anywhere for you yet, because I canât find them?
