Be patient, because this explanation is going to be pretty technical.
Innopia is a platform developer. They started in media streaming a few years and now they’re into IOT with an emphasis on media streaming.
Their MagicCast hub is based on AllJoyn, and they are a member of the AllSeen Alliance.
https://allseenalliance.org/announcement/allseen-alliance-grows-71-members-nearly-triples-member-base-nine-months
The ADSB
Microsoft developed the ADSB (AllJoyn Device System Bridge) to allow an AllJoyn system to create virtual representations of devices of other protocols, including Z wave and zigbee, so that those devices could be managed in an AllJoyn system.
The DSB adapts non-AllJoyn devices to the AllJoyn eco-system so that the adapted devices can interoperate with AllJoyn as their common language. Microsoft DSB’s support home automation systems such as Zigbee, and Z-Wave, and can even support industrial building automation systems such as BACnet. Additionally, the source code is available for customization to support other technologies
This is a one-way integration only – – it does not expose the other devices on the AllJoyn bus to the Z wave controller, for example.
https://developer.microsoft.com/en-us/windows/iot/docs/alljoyndsb
Back to Innopia
They appear to be using the ADSP for their Z wave integration. They are not themselves building any zwave devices, at least they haven’t certified any.
Instead, they have an AllJoyn hub, they have some AllJoyn devices that work with it, and they have packages which offer Z wave devices from other manufacturers, like the Aeotech and Ecolink sensors.
http://www.tradekorea.com/products/productDetail.do?action=download&productfileno=64786
All of which is to say, if you saw Innopia brand sensors, they aren’t likely to be compatible with SmartThings, and they probably weren’t zwave.
But it is quite possible that and an Innopia representative could show you an Innopia hub and tell you that it would work with SmartThings brand zigbee sensors or Z wave devices. But again, it’s a one-way integration, those devices could be exposed to their hub, but you can’t bring the information back to SmartThings again as far as I know.
If you do see an Innopia-branded zwave device, let us know.
