Alright, so I cleaned up the code and added what I think is a good Health Check. I tested in New App and all seems fine with the Nexia Doorbell.
* Nexia Doorbell Sensor - DB100Z
* Copyright 2016 DarwinsDen.com
* For installation instructions, DB100Z device review information, documentation and images,
* or for questions or to provide feedback on this device handler, please visit:
* darwinsden.com/db100z
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Author: Darwin@DarwinsDen.com
* Date: 2016-03-26
* Changelog:
* 1.4 (05/10/2018) - Added contact sensor as capability for use with smart home monitor
* 1.3 (09/25/2016) - Added display of firmware version and updated to get battery level on initial installation
* 1.2 (09/11/2016) - Added preference option for push-to-break button (vs. default push-to-make) doorbell circuit. Note: enabling
* this setting will also result in a doorbell notification if power is lost to the doorbell transformer.
* 1.1 (05/11/2016) - Added Button capability option.
* 1.0 (03/26/2016) - Initial 1.0 Release.
metadata {
definition (name: "Nexia Doorbell Sensor", namespace: "darwinsden", author: "Darwin", mnmn:"SmartThings", vid: "generic-switch") {
capability "Actuator"
capability "Switch"
capability "Momentary"
capability "Button"
capability "Contact Sensor"
capability "Sensor"
capability "Battery"
capability "Refresh"
capability "Configuration"
capability "Health Check"
attribute "status", "enum", ["off", "doorbell"]
fingerprint deviceId: "0x0701", inClusters: "0x5E, 0x86, 0x72, 0x5A, 0x73, 0x80, 0x70, 0x71, 0x85, 0x59, 0x84, 0x7A"
simulator {
preferences {
input "pushToBreak", "bool", title: "Doorbell circuit is push-to-break instead of push-to-make", defaultValue: false, displayDuringSetup: true, required: false
tiles(scale: 2) {
multiAttributeTile(name:"status", type: "generic", width: 6, height: 4) {
tileAttribute ("device.status", key: "PRIMARY_CONTROL") {
attributeState "off", label: "Off", icon:"st.Home.home30", backgroundColor:"#ffffff"
attributeState "doorbell", label: "Ringing", icon:"st.alarm.alarm.alarm", backgroundColor:"#53a7c0"
valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
state "default", label:'${currentValue}% battery', unit:""
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
valueTile("firmwareVersion", "device.firmwareVersion", width:2, height: 2, decoration: "flat", inactiveLabel: false) {
state "default", label: '${currentValue}'
main "status"
details(["status", "battery", "refresh", "firmwareVersion"])
def installed() {
refresh()
def ping() {
refresh()
def refresh() {
sendEvent(name: "status", value: "off", displayed: false, isStateChange: true)
sendEvent(name: "switch", value: "off", displayed: false, isStateChange: true)
updated()
configure()
def updated() {
// Device-Watch simply pings if no device events received for checkInterval duration of 32min = 2 * 15min + 2min lag time
sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID, offlinePingable: "1"])
log.debug ("updating")
if (pushToBreak) {
state.pushToBreak = true
else {
state.pushToBreak = false
def configure() {
log.debug ("configure() called")
def commands = []
commands << zwave.versionV1.versionGet().format()
commands << zwave.batteryV1.batteryGet().format()
delayBetween(commands,500)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd) {
def event = createEvent(descriptionText: "${device.displayName} woke up", displayed: false)
def result = []
// Request battery info on wake up if levels have not been received within last 24 hours
if (!state.lastBatteryReport || (new Date().time) - state.lastBatteryReport > 24*60*60*1000) {
result += response(zwave.batteryV1.batteryGet().format())
result += response("delay 1200")
result += response(zwave.wakeUpV1.wakeUpNoMoreInformation().format())
return result
def zwaveEvent(physicalgraph.zwave.commands.versionv1.VersionReport cmd) {
//updateDataValue("applicationVersion", "${cmd.applicationVersion}")
log.debug ("received Version Report")
log.debug "applicationVersion: ${cmd.applicationVersion}"
log.debug "applicationSubVersion: ${cmd.applicationSubVersion}"
state.firmwareVersion=cmd.applicationVersion+'.'+cmd.applicationSubVersion
log.debug "zWaveLibraryType: ${cmd.zWaveLibraryType}"
log.debug "zWaveProtocolVersion: ${cmd.zWaveProtocolVersion}"
log.debug "zWaveProtocolSubVersion: ${cmd.zWaveProtocolSubVersion}"
setFirmwareVersion()
createEvent([descriptionText: "Firmware V"+state.firmwareVersion, isStateChange: false])
// Unexpected command received
def zwaveEvent (physicalgraph.zwave.Command cmd) {
log.debug("Unhandled Command: $cmd")
return createEvent(descriptionText: cmd.toString(), isStateChange: false)
def switchOffVerification() {
if (state.bellIsRinging) {
log.debug("${device.displayName} switchOffVerification setting switch off")
sendEvent(name: "status", value: "off", descriptionText: "Button released via verification check", isStateChange: true)
state.bellIsRinging = false
sendEvent(name: "contact", value: "closed", displayed: false, isStateChange: true)
//Battery Level received
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def result = null
state.lastBatteryReport = new Date().time
def batteryLevel = cmd.batteryLevel
log.info("Battery: $batteryLevel")
result = createEvent(name: "battery", value: batteryLevel, unit: "%", descriptionText: "Battery%: $batteryLevel", isStateChange: true)
return result
//Notification received
def zwaveEvent(physicalgraph.zwave.commands.notificationv3.NotificationReport cmd) {
def result = []
// if the bell is not already ringing, record as a button press. We can't always trust an event of 1 to be a
// button press if messages arrive out of order or are missed
if (!state.bellIsRinging) {
if (!pushToBreak | cmd.event == 0) //Event 1 will never be a doorbell trigger for a push to break circuit
// bell is not ringing - signal a button press
state.bellIsRinging = true
log.debug("${device.displayName} notification event = $cmd.event triggered switch on")
runIn(10, switchOffVerification) //set to turn off switch in 10 seconds in case the button release event is missed
result += createEvent(name: "status", value: "doorbell", descriptionText: "Button pressed", isStateChange: true)
result += createEvent(name: "switch", value: "on", displayed: false, isStateChange: true)
result += createEvent(name: "momentary", value: "pushed", displayed: false, isStateChange: true)
result += createEvent(name: "button", value: "pushed", data: [buttonNumber: "1"], displayed: false, isStateChange: true)
result += createEvent(name: "contact", value: "open", displayed: false, isStateChange: true)
} else {
// bell is ringing - signal a button release
log.debug("${device.displayName} notification event = $cmd.event triggered switch off")
result += createEvent(name: "status", value: "off", descriptionText: "Button released", isStateChange: true)
result += createEvent(name: "switch", value: "off", displayed: false, isStateChange: true)
result += createEvent(name: "contact", value: "closed", displayed: false, isStateChange: true)
return result
def setFirmwareVersion() {
def versionInfo = ''
if (state.firmwareVersion) {
versionInfo=versionInfo+"Firmware V"+state.firmwareVersion
else {
versionInfo=versionInfo+"Firmware unknown"
sendEvent(name: "firmwareVersion", value: versionInfo, isStateChange: true)
def parse(description) {
def result = null
log.debug (description)
if (description.startsWith("Err")) {
result = createEvent(descriptionText: description, isStateChange: true)
} else if (description != "updated") {
def cmd = zwave.parse(description, [0x71: 3, 0x80: 1])
if (cmd) {
result = zwaveEvent(cmd)
} else {
log.debug("Couldn't zwave.parse '$description'")
return result
