So far the new app has not been very good with Z-Wave in my opinion .
I have a never before used (still in box) Intermatic HA04 outside outlet. I am trying to add it to my v2 hub using the new app and it is not found. I am trying to add it as a generic zwave device and it is just not being found. Do I need to do something other than have it within 10 feet of the hub?
I tried all sorts of combinations with turning on and trying to find the outlet.
P.S. Does anyone know how to exclude devices? Is there a way to refresh the z-wave routes?
Additionally, have you already attempted to locate the Generic Z-Wave device by performing a nearby scan? Using the pathway (+) > Device > Scan Nearby.
Do you have the “Ask to add new devices” popup enabled in your SmartThings settings for when your Phone detects a nearby device that is able to be added to SmartThings?
It should just be a matter of setting the hub scanning using either Scan Nearby or the Generic Z-Wave onboarding so the green LED is flashing on the hub, and then pressing the button on the outlet . If that doesn’t work then you could try excluding the device first as @jkp described.
