I used the device handler and setup procedure found here on the forums and everything seems to go fine. The problem that I am having is that the setpoints and current temp are not populating. I cant tell if the mode, fan and occupancy icon are working as expected. Has anyone else run into this?
Have you hit refresh? This should update with the current status. You’ll also need to use pollster or rule machine expert features to get the status at your desired interval.
Hitting refresh doesn’t do anything.
Mine looks like your images but blank.
Can you help?
If the refresh doesn’t do anything you need to check the logs in the IDE. My guess is your password/setup is incorrect.
