I think? Someone please correct me if I’m wrong. When your devices (whatever they are) perform initial connection to hub. They exchange data about what the thing is and and values of certain parameters. Smartthings uses this data to setup your device and add it to your system. If anything happens during this initial connection (bad data, missing information, ect…) weird things happen.
Can’t control, doesn’t show up ect…
My guess is you need to remove your protects using the IDE. Then reinstall them using this device handler or remove this device handler, install nest manager, then reconnect your protects.
Just my opinion, what you do is up to you.
I had a similar situation where my protects were not visible in my android app. They were visible in the IDE. To fix it is removed the protects in the IDE, then removed the protect device software I had installed in the IDE, then installed the Nest manager software in the IDE, then installed my protects using that software.
If you look like less than 10 post up in this thread, someone else was also having issues. Someone else replied with a link to nest manager as the fix.
There is no official smartthings one. Nest Manager is another custom device to interface Nest to smartthings.
Like @RLDreams said scroll up for the “Nest Manager” link. Go to that thread and follow the directions.
BEFORE you do that. Log into the IDE. Select devices, select your protect and remove it.
Then go the the Device Type Tab, select the Nest Protects software that THIS thread had you install and remove it.
It’s all in the post right above here made by myself and others.
Hmmm… I managed to get one installed somehow, and it shows present.
The 2nd gen Protects have some kind of presence (night light turns on for example, and I thought that they all communicate with each other with this kind of stuff).
My protects can tell when you walk by. They then turn on a night light for that individual protect. I believe this is an option you can configure along with brightness of light.
I recommend you use this device type for your Protects.
So, I’ve read it all nad tried to follow the intructions with no luck. First I added a new Device Handler with the code from this thread. I also added the username, password and Mac-adress to the code as the instructions suggested but I think theres something wrong. The device wont work properly and I culdn’t find Nest Protect as a device type when i tried to add a new device. Please give me updated instructions because these wont work.
If I understand you correctly, you are trying to add the Nest Protect stand alone as a Thing. You can’t do that. You need to install the NST Manager ‘suite’ with SmartApp and related device handlers.
I noticed Nest Protect is no longer available because the custom DTH and SmartApp are gone with Groovy being gone. I know there is a limited Nest integration with some devices but apparently the API is different on Nest Protect.
My question:
Does SmartThings have a future plan in place to build that integration with Nest Protect? I can wait if need me.
If not, then what do you all recommend that works with SmartThings that is battery powered? I am kind of apprehensive about adding more Z-Wave or Zigbee if Thread is to replace them in the future, thus forcing me to change those devices should I need to change hubs.
