Hi, I have followed all te steps to get the smartapp nest manager working.
Have only one problem. After I login to nest and accept I get A code from nest(use code to Connect with nest) that I must use to connect SmartThings (nest-manager) to nest but where do I put te code?
You will generally get the quickest answer if you ask in the author thread for the custom code that you were using. The author will be automatically notified whenever a new post is added to that thread. And other people who are using the same code may also be able to help.
In this particular case, ask your question in the following thread:
