Nest device type with a bunch of new features
I have actually notice this device type is not working for me at all. the temp reading is incorrect and I’m not able to change the temp. It seems totally unresponsive.
Anyone else?
Ok, I’ll give that a try. Thanks.
That fixed the issue with the Nest itself. However, when I’m using them with an external temp sensor, the Keep me Cozy 2 does not change the temperature.
I followed the instructions and added nest to smartthings. Everything seems to be working except polling. Smartthings will not show the current status unless I hit the refresh button. I thought maybe I wan’t giving it enough time, but I let this morning it was showing the state from yesterday afternoon. I hit refresh and everything is fine. Is this normal?
I’ve never been able to get Keep Me Cozy II to work with my Nest. I always fill in everything and get "“Failed to save page: defaultPage”. I tried adding the most recent Nest device type above and transferring my Nest over to that type, but it made no difference. Any suggestions?
Thank god I’m not the only one.
Actually, I was thinking about this. Is there a way to just add an alternate temp sensor in the Nest device type instead of having to use Keep Me Cozy II?
In addition, can someone please explain how keep me cozy II works? When the temp set point changes does it just check the alternate sensor and then add how ever many degrees it needs to match the set point? It so, this would work horribly.
Trying to get set up. I copied the code into the device type and have edited the preferences with my login and serial info but when I tap on Nest under devices, the smartthings app immediately crashes. I do see the device controls for a split second.
Any ideas?
I also have the same problem. iPhone 6s.
Also just blowing up with an iPhone 6s.
Hiya. Check out the thread below - I made the suggestions there made by desertblade and it immediately worked. Happy times.
Got it working - made a comment in the other thread about what specific code had to be changed. I also had odd characters in the code before the degree symbol - an accented capital A. It just displayed funny. I just deleted it.
I also changed the color of the humidity up/down buttons to green to match the humidity percent display as having them match the cool up/down buttons was confusing…
Thanks!!!
There is one thing that is not displaying for me on this Nest device type. I have a setup where I have a propane furnace as the Alt heat. So, within Nest it is set as Dual Fuel with Heat Stage 1 (Electric), Heat Stage 2 (Electric) and Heat Alt 1 (Propane).
When the Propane furnace is running (when it is below the temp that I have set for Alt heat), this device type registers the operation as idle. I think that is due to only having
def emergencyHeat() {
	setThermostatMode('heat')
and
def setThermostatMode(mode) {
	mode = mode == 'emergency heat'? 'heat' : mode
	api('thermostat_mode', ['target_change_pending': true, 'target_temperature_type': mode]) {
		mode = mode == 'range' ? 'auto' : mode
		sendEvent(name: 'thermostatMode', value: mode)
		poll()
I do not know enough about the Nest API to know what to add though to make this show heating when it is using Stage 2 and Alt 1.
I’ve got Nest connected to my Amazon Echo via ST. I am able to say “Alexa, set Nest to 70” and it works great. Is there a way to tell Amazon Echo to turn “down the temp by one degrees”, or better yet, “Alexa, turn Nest cooler.” so that Nest will drop the temp by 1 degrees (and vice versa to tell it to make it warmer). Since I sometimes don’t know the exact temp that Nest is set at (eg across the room and the motion sensor doesn’t have the device screen on, it would be great (if I’m warm or cold) to just tell Alexa to make it warmer or cooler. Thoughts? Thanks!
@Chris_McCown, if you are still looking, look for post 29380, “alexa helper”. Between that and rule machine (search) pretty much nothing you can not do
Here’s a list of Ecobee commands that all work with my Nest:
https://www.ecobee.com/faq/which-alexa-voice-commands-can-i-use-with-my-ecobee/
Has anyone tried leaving “learning mode” on when using Nest with ST? Good or bad results?
I disabled the Nest learning mode. I use Nest Manager app developed by tonesto7 to have Nest follow my ST routines. I work different shifts and the Nest learning feature was would always be trying to catch up to my schedule and I was having to constantly adjust it.
Also some of those ecobee commands don’t work with my Alexa talking to Nest. I have to tell Alexa the temperature I want Nest set at.
Yep I long ago disabled Nest learning and auto-away, Nest Manager handles everything flawlessly.
