I have tried all the handlers I found in this thread. The best thing I can get from this sensor is motion and battery. I was hoping for temp. Any news from anyone? Thanks.
Take a look at these handlers. Should be the same devices and there you can set the LUX reporting threshold.
I think the default is a change of 100LUX for it to report a new value
Hi, just got one of the Neo motion sensors which is a great little sensor but I want to disable the red led from flashing on motion. I’ve tried the zooz DH, the neo DH and Fibaro DH but none of them actually diable the led when I set it to be turn off. Anyone had any luck with disabling the led? Thanks
I used the fibero DH for awhile then started using the coolcam motion DH. These are by far my favorite motion sensors. They work flawless and have very good sensing capabilities. I have about 4 different brands of motion sensors and these are the easiest to install,configure and just work. I haven’t even had to put a battery in a single one yet too.
Thanks for the info, I’ve somehow managed to get the led not to come on after trying lots of different device handlers. I’ve settled on the Fibaro device handlers as it does the motion and the temperature sensing.
Anyone knows how to pair the Neo Coolcam to Smartthings? My does not show in “devices” and “catch all”. I try to rapidly push the button on the device and the red light flashes five times. Is it any other way of paring?
Hi @mate - I just bought a NEO Compact Z-Wave Plus motion sensor, which is very similar to the zooZ Mini Sensor. From within my SmartThings IDE, under the Templates tab, I’m not able to find the brand “zooZ”. I’d like to be able to find it and learn where to change the code to disable the red light. Any advice you can give me? (Newbie here.)
Hi @Neb9 - I also own a NEO motion sensor and I also need to disable the red LED light. I read that you were able to do just that, using a Fibaro device handler. I’m a newbie and got as far as logging into my ST STE and I found the Fibaro motion sensor device handler under the Template tab. Would you please share with me … where in the code of that Fibaro DTH is the information about the red LED light, and what I should change in the code to disable the red LED light?
Thanks so much @zorro18 ! A couple of questions (I’ve never used a DH before).
On my SmartThings Classic app on my Android phone, under Things, when I click on the device name and view ‘Right Now’, under where it says ‘No Motion’ it says ‘Pending’. How long does it typically take for the ST app to see the new DH?
In your custom DH, I made a change in the following two lines … I changed the 0 to 1 for Disable LED Blink, and I changed the 1 to 0 for Enable LED Blink. Did I do the wrong thing? (Because the red LED still flashes when there’s motion.)
These are original lines of code: (I then switched the 1 and the 0)
<Item label="Disable LED Blink" value="0" />
<Item label="Enable LED Blink" value="1" />
If I did the wrong thing, should I change things back in the DH code at my ST IDE and click on the Publish button again?
Anyone get the LUX sensor to work on the Neo Coolcam PIR sensor? There are several DHs listed here? Which ine have all three sensors working - motion, temp, and lux?
As far as i know none of the mini sensors have temperature or humidity, only motion and lux. A few of the device handlers work. I was using the Zooz mini one with my coolcam mini sensor and it works ok.
