Neo Coolcam Door sensor Battery status
Hello, i have the Neo Coolcam Door/windows sensor.
To get this to work i used the dome device handler that works but it doesn’t give feedback about my battery status.
Does somebody got this sensor working including the battery status?
Have you tried using the standard ST Door/Window DTH (secure and non secure versions)?
that sensor’s fingerprint was added to the standard z-wave door window sensor handler. Try it.
Thanks for the reply. I changed the device handler to the default one but my battery is still 100% :smile:.
This sensor is active for 4 months so shoud be at least 98%.
Do you guys have more ideas?
Most battery readings don’t drop in that small of an increment. It probably won’t show a new battery reading until its below 90%
