I new to programming in webcore and need advise.
I have a thermostat the is giving heat to the bathroom floor.
Very simple scenario: When home mode is activated set temp to 23 degrees celicius. When the humidity is high set the temperature to 25 degrees celcius.
- It feels like the smartThings hub is slow after implementing the code, should i use a timer with intervall instead of checking criterias continiusly?
2.Does the logic make sense?
