Hi guys,
I recently got a Montigo gas fireplace and I want to be able to control it via my SmartThings hub with Z-Wave.
The fireplace I have use this as controller : https://www.montigo.com/drive/uploads/2017/11/XG0677-EN-Proflame-2-Instructions-151123.pdf
I think I can use this zwave dry contact relay to control the on/off function : https://www.amazon.ca/dp/B01MSEG2J1/ref=pe_3034960_233709270_TE_item
As far as I know, I only need to provide 120v power to the relay module and then connect the relay load to the controller.
Am I on the right track? Anybody got this to work?
PS : I’m not an electrician or anything and I will not wire everything up by myself since I don’t really know what I’m doing.
