So I’ve been having some difficulty getting this to work. It keeps throwing an error message that I can’t seem to shake. So please help this noob. Thanks in advance.
“bridge”: {
“name”: “Homebridge”,
“username”: “xxxxxxxxxxx”,
“port”: 51826,
“pin”: “031-45-154”
"description": "This is an example configuration file with all supported devices. You can use this as a template for creating your own configuration file containing devices you actually own.",
"platforms": [
"platform" : "Nest",
"name" : "Nest",
"username" : "xxxxxxxxx@xxxxxxx.com",
"password" : "xxxxxxxxxxxx"
"platform": "SmartThings",
"name": "SmartThings",
"app_id": "xxxxxxxxxxxxxxx",
"access_token": "xxxxxxxxxxxxxxx"
"platform": "LogitechHarmony",
"name": "Living Room"
"accessories": [
"accessory": "LiftMaster",
"name": "Garage Door",
"description": "This shim supports LiftMaster garage door openers that are already internet-connected to the 'MyQ' service.",
// "requiredDeviceId", "<ID of door if you have multiple doors, prompted by shim during startup if needed>",
"username": "xxxxx@xxxxx.com",
"password" : "xxxxxxxx"
