Mystery Routine
I was looking through my ST history and came across this “Test” routine. It seems to run randomly nearly every day and at different time. I have no such either manually run or automatic routine. How can I see what it does and what’s triggering it, or remove it?
Ever used Rules API? (not sure if that is listed as Routine in History or not)
Yes, rules show as ‘Routine activated’
I don’t believe I have used the Rules API. How else could this show?
If you use the API Browser+ to see all Routines, and any Rule, then you will be able to delete it from there if that is the case.
