Hi!,
I think I’ve found an interesting bug in MyEcobeeInit. I believe it cannot handle more than 14 thermostats. In my use case I have many locations, and MyEcobeeInit throws an exception.
I believe the offending line is this one, online 779:
atomicState?.thermostatList = stats
error java.lang.SecurityException: Getting properties on class physicalgraph.exception.StateCharacterLimitExceededException is not allowed (getThermostatInfo)
Hi, unless the StateCharacterLimitExceededException has changed (usually 100 000 characters), I doubt that the *thermostatList (*even with 15 tstats) will reach that limit.
You haven’t specified which version of MyEcobeeInit you’re using, so I suspect that you’re using an older version
I’d recommend the following :
First, download the latest version (as some performance improvements have been made this year) ;
Second, if you have 15 tstats, this is likely a commercial usage. I’d then strongly suggest to contact me at services@maisonecomatiq.com for consulting services.
I am using the 12/27/2020 version and will email you. Via several hours of testing, I can confirm that the exception above is thrown on the line above.
