I just did an update on My Q lite to the latest version and everything was working fine. Then after 2 days one of my garaged doors arrival routines stopped working. I use Life360 as a presence sensor. It shows me present. All other devices trigger correctly, lights etc. If I manually run the routine the garage door works. The other garage door routine works just fine, opens on presence etc. Basically I am stumped. Any input would be greatly appreciated.
If you are using the Classic app, open the life360 device and click on the recently tab to verify it is working.
Yes it is working. It shows presence and the other devices in the routine work, lights etc when I arrive. It is just the garage door opening. Thanks for the reply
