I am looking to see if anyone has written a smart app for the following.
Here is what I have-
I have a multi sensor on a window, and I want it to alert me when it is open if the temperature outside or on the smart sensor is above x value.
Basically I am trying to monitor my kids windows to see if they are left open after x temperature so we don’t turn on the AC. Eventually I would like to have the app alert me but also not turn on or off a certain switch (which will be connected to the whole house fan)
Thanks in advance if any has a framework I could leverage to write the app.
In the IDE, create a new smartapp and click the browse smartapps in the top right corner. You will see the code for “its too cold” you can reverse this for rising temperature. You can also put in a condition for the multi sensor having to be open before it alerts of the temp. You can get the sensor contact code from “left it open” app.
its a rough go at the code for this. I hope others can polish it for you.
* Open window letting hot air in?
* Copyright 2014 Brian Critchlow
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Open window letting hot air in?",
namespace: "docwisdom",
author: "Brian Critchlow",
description: "check if an open window is letting hot air in",
category: "",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("Monitor this door or window") {
input "contact", "capability.contactSensor"
section("Monitor the temperature...") {
input "temperatureSensor1", "capability.temperatureMeasurement"
section("When the temperature rises above...") {
input "temperature1", "number", title: "Temperature?"
section("Via text message at this number (or via push notification if not specified") {
input "phone", "phone", title: "Phone number (optional)", required: false
def installed() {
log.trace "installed()"
subscribe()
def updated() {
log.trace "updated()"
unsubscribe()
subscribe()
def subscribe() {
subscribe(contact, "contact.open", doorOpen)
subscribe(contact, "contact.closed", doorClosed)
def doorOpen(evt)
log.trace "doorOpen($evt.name: $evt.value)"
def contactState = contact.currentState("contact")
if (contactState.value == "open") {
subscribe(temperatureSensor1, "temperature", temperatureHandler)
} else {
log.warn "doorOpenTooLong() called but contact is closed: doing nothing"
def doorClosed(evt)
log.trace "doorClosed($evt.name: $evt.value)"
def temperatureHandler(evt) {
log.trace "temperature: $evt.value, $evt"
def tooHot = temperature1
def mySwitch = settings.switch1
// TODO: Replace event checks with internal state (the most reliable way to know if an SMS has been sent recently or not).
if (evt.doubleValue >= tooHot) {
log.debug "Checking how long the temperature sensor has been reporting >= $tooHot"
// Don't send a continuous stream of text messages
def deltaMinutes = 10 // TODO: Ask for "retry interval" in prefs?
def timeAgo = new Date(now() - (1000 * 60 * deltaMinutes).toLong())
def recentEvents = temperatureSensor1.eventsSince(timeAgo)
log.trace "Found ${recentEvents?.size() ?: 0} events in the last $deltaMinutes minutes"
def alreadySentSms = recentEvents.count { it.doubleValue <= tooHot } > 1
if (alreadySentSms) {
log.debug "SMS already sent to $phone1 within the last $deltaMinutes minutes"
// TODO: Send "Temperature back to normal" SMS, turn switch off
} else {
log.debug "Temperature rose above $tooHot"
sendMessage()
void sendMessage()
def msg = "${contact.displayName} has been left open and the temperature rose above the threshold of ${temperature1}"
log.info msg
if (phone) {
sendSms phone, msg
else {
sendPush msg
