I am running the Smarthings App on an Ipad Air. When I go to the SmartApps tab under home I see two instances of TCP bulbs. When I try to uninstall one or both of the Tcp Bulbs SmartApps I get a message that says: An unexpected error occurred. This happens even if I remove all of the connected bulbs from the Tcp Bulbs SmartApp. Has anyone else experienced this problem, and if so, have you worked out a fix? This is a problem because my Amazon Echo discovers the bulbs twice, which makes keeping track of my connected devices difficult. I am running the SmartThings hub v2.
Did this ever get fixed? Having the same problem…
