I wrote an app that takes care of a few of these problems. It deals with presence, modes, and multiple jawbones.
* Sleepy Time with Presence
* Copyright 2014 Eric Roberts
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Sleepy Time with Presence",
namespace: "baldeagle072",
author: "Eric Roberts",
description: "Will only trigger the hello home phrase on the jawbone if the person is at home. If both people are home, both people have to be in sleep mode.",
category: "Mode Magic",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
page(name: "selectPhrases")
def selectPhrases() {
dynamicPage(name: "selectPhrases", title: "Configure Your Jawbone Phrases.", install: true, uninstall: true) {
section("Select user 1's Jawbone UP24 and presence sensor") {
input "jawbone1", "device.jawboneUser", title: "Jawbone UP24", required: true, multiple: false
input "presence1", "capability.presenceSensor", title: "Presence", required:true, multiple: false
section("Select user 2's Jawbone UP24 and presence sensor") {
input "jawbone2", "device.jawboneUser", title: "Jawbone UP24", required: true, multiple: false
input "presence2", "capability.presenceSensor", title: "Presence", required:true, multiple: false
def phrases = location.helloHome?.getPhrases()*.label
if (phrases) {
phrases.sort()
section("Hello Home Actions") {
log.trace phrases
input "sleepPhrase", "enum", title: "Enter Sleep Mode (Bedtime) Phrase", required: true, options: phrases
input "wakePhrase", "enum", title: "Exit Sleep Mode (Waking Up) Phrase", required: false, options: phrases
section("Turn on - waking") {
input "wakeOnSwitches", "capability.switch", multiple: true, required: false
section([mobileOnly:true]) {
label title: "Assign a name", required: false
mode title: "Set for specific mode(s)", required: false
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
log.debug "Subscribing to sleeping events."
subscribe (jawbone, "sleeping", jawboneHandler)
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
subscribe (jawbone1, "sleeping", jawboneHandler1)
subscribe (jawbone2, "sleeping", jawboneHandler2)
initialize()
def initialize() {
// TODO: subscribe to attributes, devices, locations, etc.
def jawboneHandler1(evt) {
jawboneHandler(presence1, presence2, jawbone2, evt)
def jawboneHandler2(evt) {
jawboneHandler(presence2, presence1, jawbone1, evt)
def jawboneHandler(primaryPresence, secondaryPresence, secondaryJawbone, evt) {
def primaryPresenceValue = primaryPresence.latestValue("presence")
def secondaryPresenceValue = secondaryPresence.latestValue("presence")
log.debug "In Jawbone Event Handler, Event Name = ${evt.name}, Value = ${evt.value}"
if (primaryPresenceValue == "present") {
log.debug "User Present"
if (evt.value == "sleeping") {
if (secondaryPresenceValue == "present") {
if (evt.value == secondaryJawbone.latestValue("sleeping")) {
sendNotificationEvent("Sleepy Time performing \"${sleepPhrase}\" for you as requested.")
log.debug "Sleepy Time performing \"${sleepPhrase}\" for you as requested."
location.helloHome.execute(settings.sleepPhrase)
} else {
log.debug "Second person not asleep"
} else {
else {
if (wakePhrase) {
sendNotificationEvent("Sleepy Time performing \"${wakePhrase}\" for you as requested.")
log.debug "Sleepy Time performing \"${wakePhrase}\" for you as requested."
location.helloHome.execute(settings.wakePhrase)
wakeOnSwitches?.on()
} else {
log.debug "User Not Present"
