You could do it by sending out multiple presences for yourself based on different location services and then trigger the event you wanted based on which presence you wanted to use for it.
For example, smartthings has an official integration with Life360. I believe it’s possible to use the same phone for both the SmartThings native presence and life 360 presence, but you need to check on that to be sure.
You could definitely use IFTTT location to turn on a virtual presence sensor.
So I feel confident that you should be able to find a way to do it, but you may have to experiment with a couple of different methods to get exactly what you want.
