Hi! This is my first post so… I’ve now spent around 4 hours trying to figure out how… in away/Armed, I can set my siren to trigger only when a door sensor and motion sensor are BOTH triggered.
Help is very much appreciated.
Welcome!
Which controller do you have? The ADT /SmartThings security panel? Or the original SmartThings Hub? The Security features work somewhat differently.
I believe if you are just using the built in options for SHM, it’s an either scenario.
You could create a Virtual Contact (simulated) and then use a rule engine such as webCoRE to say:
If motion is active
And
Contact is open
Then using Virtual Contact
Set Virtual Contact=Open
Else
Set Virtual Contact=Close
Then use the Virtual Contact as the Contact in SHM
You create Virtual Devices in the SmartThings IDE or you can use a custom app such as Switch Mania.
webCoRE is a popular custom app that you would want to get a handle on upfront as it is very useful for creating simple and complex rules.
