First off I want to start off saying that it was easy to install on my door. Its showing the door activity, open and closure fine, temp shows. The only thing that I notice is what I assume is the vibration shows inactive. Is there a way to activate it? Do I need to do anything special? Thank you in advance for any input.
It should show activity if you swing the door open. Check the activity of the door as well.
Thank you for the reply, I was a little premature in checking that actual app when I messed with the door itself. Is there a way to set up alerts when the vibration kicks off?
