Had a good search but cannot find a bracket or option which will allow me to mount the Smart hub on the wall.
A lot of manufacturers if they dont provide a separate bracket, provide a screw hole on the underside of any device, so that you can slot the hub against a screw.
So
Is there a bracket
if not, could we please request that V3 hub onward has a screwhole on the underside to make it more useful for mounting.
brilliant - thats a really useful link thank you! Im not going to go with the screw option of screwing the backplate as I will be mounting on back of TV cabinet. I will probably go with the command strips.
