I have a string of dumb lights in the garden, which I want to keep, but ideally want to be able voice control them, and set them to be triggered by a motion sensor after dark.
I’m thinking I need a socket (or power strip) and motion sensor that will talk to my ST hub and should be able to link the two from there?
Saw this for a socket. It’s smartlife compatible but I dont think that’ll do the trick.
Assuming you are in the UK, based on the link you gave, Meross is a well engineered Wi-Fi brand and has a SmartThings integration from the manufacturer:
So that leaves the question of the sensor. Phillips hue make an outdoor motion sensor which can work Directly with a smartthings Hub without a hue bridge using a custom DTH.
