Hello all,
From yesterday around 8pm all my motion sensors smart things stop working, no motion detection any more , fibaro motion sensor working properly.
Do you have similar issues?
Hello all,
Sometimes they get stuck. Pull the battery and re-insert. Usually works for me.
Thank you for tip,check this evening and let you know work or not , any way its annoying one day working ok other not
working , thanks for help
yep… thanks this worked for me too.
I had a smartthings motion sensor stop working on me yesterday. To correct the problem, I simply pushed on it. On the outside cover. That must have been enough “jarring” to get it working again. Its fine now. Weird.
I had 3 get in a lock state yesterday. Battery pull fixed 2.
1 I get, but 3 on the same day is weird.
I I solved the my problem. Reason: Due to the frequency of my Access Point and Modem Wifi I’ve done as follows: ~ Channel: 1 ~ Mode: 11n only ~ Bankwidth: 40Mhz.
