##Monoprice Z-Wave Smoke Detector##
This is a device type for the Monoprice Z-wave Smoke detector - No Logo.
This device supports four types of events: Smoke detected, smoke cleared, tamper alarm, and low battery alarm. When the TEST button is pressed the smoke detector will report smoke, there is no special code for the test button.
##Capabilities and Attributes##
Capabilities:
capability.smokeDetector
capability.sensor
capability.battery
Attributes:
battery - numeric value with the percent of battery life
smoke - “detected” or "clear"
deviceAlert - “clear”, “tamper”, or “lowbat”
##Download##
The latest code can always be found here: Monoprice Z-Wave Smoke Detector
But in the interest of being easier to find through Google, here is the full source code:
* Monoprice Z-Wave Smoke Detector
* Copyright 2015 Jim Worley
* Updated by Cuboy29: 8/24 - Add ability to change wakeup time.
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* - Original code by @NoName4444
* - Wakeup times and battery reporting fix by @Cuboy29
preferences {
// manufacturer default wake up is every hour; optionally increase for better battery life
input "userWakeUpInterval", "number", title: "Wake Up Interval (seconds)", description: "Default 3600 sec (10 minutes - 7 days)", defaultValue: '3600', required: false, displayDuringSetup: true
metadata {
definition (name: "Monoprice Z-Wave Smoke Detector", namespace: "Smartthings", author: "Jim Wolley") {
capability "Smoke Detector"
capability "Sensor"
capability "Battery"
attribute "alarmState", "string"
attribute "deviceAlert", "string"
//Support Command Class
//0x30 Sensor Binary
//0x71 Alarm/Notification
//0x72 Manufacture Specific
//0x86 Version
//0x85 Association V2
//0x80 Battery
//0x84 Wake Up V2
fingerprint deviceId: "0xA100", inClusters: "0x30,0x71,0x72,0x86,0x85,0x80,0x84"
simulator {
status "smoke/test": "command: 7105, payload: 01 FF 00 FF 01 02 00 00"
status "clear": "command: 7105, payload: 01 00 00 FF 01 02 00 00"
status "tamper" : "command: 7105, payload: 01 FF 00 FF 01 FE 00 00"
status "wakeUp Device" : "command: 8407, payload:"
status "battery 100%": "command: 8003, payload: 64"
status "battery 5%": "command: 8003, payload: 05"
tiles {
standardTile("smoke", "device.alarmState", width: 2, height: 2) {
state("clear", label:"clear", icon:"st.alarm.smoke.clear", backgroundColor:"#ffffff")
state("smoke", label:"SMOKE", icon:"st.alarm.smoke.smoke", backgroundColor:"#e86d13")
state("tamper", label:"tamper", icon:"st.alarm.smoke.smoke", backgroundColor:"#e86d13")
state("lowbat", label:"lowbat", icon:"st.alarm.smoke.smoke", backgroundColor:"#e86d13")
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'${currentValue}% battery', unit:""
main "smoke"
details(["smoke", "battery"])
log.debug "Smoke Detector description: $description"
def results = []
if (description.startsWith("Err")) {
results << createEvent(descriptionText:description, displayed:true)
} else {
def cmd = zwave.parse(description, [0x71: 2, 0x84: 2, 0x80: 1])
if (cmd) {
//log.debug "Smoke Detector CMD: $cmd"
//log.debug "Smoke Detector CMD properties: ${cmd.getProperties()}"
zwaveEvent(cmd, results)
log.debug "\"$description\" parsed to ${results.inspect()}"
return results
def createSmokeEvents(name, results) {
if (name == "smoke") {
// these are displayed:false because the composite event is the one we want to see in the app
results << createEvent(name: "smoke", value: "detected", descriptionText: "$device.displayName smoke was detected!", displayed: false)
// This composite event is used for updating the tile
results << createEvent(name: "alarmState", value: name, descriptionText: text)
} else if (name == "clear") {
results << createEvent(name: "smoke", value: "clear", descriptionText: "$device.displayName smoke is clear!", displayed: false)
} else if (name == "tamper"){
results << createEvent(name: "smoke", value: "tamper", descriptionText: "$device.displayName has been tampered with!", displayed: false)
results << createEvent(name: "deviceAlert",value: name, descriptionText:"$device.displayName has been tampered with!")
} else if (name == "lowbat"){
results << createEvent(name: "smoke", value: "lowbat", descriptionText: "$device.displayName has been tampered with!", displayed: false)
results << createEvent(name: "deviceAlert",value: name,descriptionText:"$device.displayName has a low battery!")
def zwaveEvent(physicalgraph.zwave.commands.alarmv2.AlarmReport cmd, results) {
if (cmd.zwaveAlarmEvent == 2){
createSmokeEvents(cmd.alarmLevel ? "smoke" : "clear", results)
} else if (cmd.zwaveAlarmEvent == 254){
createSmokeEvents("tamper", results)
} else {
createSmokeEvents("lowbat", results)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd, results)
createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)
def userWake = getUserWakeUp(userWakeUpInterval)
// Only ask for battery if we haven't had a BatteryReport in a while
if (!state.lastbatt || (new Date().time) - state.lastbatt > 50*60*1000) {
results << response(zwave.batteryV1.batteryGet())
results << response("delay 1500") // leave time for device to respond to batteryGet
// If user has changed userWakeUpInterval, send the new interval to the device
if (state.wakeUpInterval != userWake){
state.wakeUpInterval = userWake
log.debug "Setting New WakeUp Interval to: " + state.wakeUpInterval
results << response(zwave.wakeUpV2.wakeUpIntervalSet(seconds:state.wakeUpInterval, nodeid:zwaveHubNodeId))
results << response("delay 200")
results << response(zwave.wakeUpV2.wakeUpIntervalGet())
results << new physicalgraph.device.HubAction(zwave.wakeUpV2.wakeUpNoMoreInformation().format())
results << createEvent(descriptionText: "$device.displayName woke up", isStateChange: false)
results << createEvent(name: "deviceAlert",value:"clear",descriptionText:"No more alerts are found!")
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd, results) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "$device.displayName battery is low!"
} else {
map.value = cmd.batteryLevel
results << createEvent(name: "deviceAlert",value:"clear",descriptionText:"Reported Battery Level: $cmd.batteryLevel")
results << createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpIntervalCapabilitiesReport cmd, results) {
def map = [ name: "defaultWakeUpInterval", unit: "seconds" ]
map.value = cmd.defaultWakeUpIntervalSeconds
map.displayed = false
state.defaultWakeUpInterval = cmd.defaultWakeUpIntervalSeconds
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpIntervalReport cmd, results) {
def map = [ name: "reportedWakeUpInterval", unit: "seconds" ]
map.value = cmd.seconds
def zwaveEvent(physicalgraph.zwave.Command cmd, results) {
def event = [ displayed: false ]
event.linkText = device.label ?: device.name
event.descriptionText = "$event.linkText: $cmd"
results << createEvent(event)
private getUserWakeUp(userWake) {
if (!userWake) { userWake = '3600' } // set default 1 hr if no user preference
// make sure user setting is within valid range for device
if (userWake.toInteger() < 60) { userWake = '600' } // 10 minutes - Mininum
if (userWake.toInteger() > 604800) { userWake = '604800' } // 1 week - Maximum
return userWake.toInteger()
