I made some changes that should send battery status.
UPDATE: fixed battery status always being requested with every wakeupnotification event.
* Monoprice Z-Wave Smoke Detector
* Copyright 2015 Jim Worley
* Updated by Cuboy29: 8/24 - Add ability to change wakeup time.
preferences {
// manufacturer default wake up is every hour; optionally increase for better battery life
input "userWakeUpInterval", "number", title: "Wake Up Interval (seconds)", description: "Default 3600 sec (10 minutes - 7 days)", defaultValue: '3600', required: false, displayDuringSetup: true
metadata {
definition (name: "Monoprice Z-Wave Smoke Detector", namespace: "Smartthings", author: "Jim Wolley") {
capability "Smoke Detector"
capability "Sensor"
capability "Battery"
attribute "alarmState", "string"
attribute "deviceAlert", "string"
//Support Command Class
//0x30 Sensor Binary
//0x71 Alarm/Notification
//0x72 Manufacture Specific
//0x86 Version
//0x85 Association V2
//0x80 Battery
//0x84 Wake Up V2
fingerprint deviceId: "0xA100", inClusters: "0x30,0x71,0x72,0x86,0x85,0x80,0x84"
simulator {
status "smoke/test": "command: 7105, payload: 01 FF 00 FF 01 02 00 00"
status "clear": "command: 7105, payload: 01 00 00 FF 01 02 00 00"
status "tamper" : "command: 7105, payload: 01 FF 00 FF 01 FE 00 00"
status "wakeUp Device" : "command: 8407, payload:"
status "battery 100%": "command: 8003, payload: 64"
status "battery 5%": "command: 8003, payload: 05"
tiles {
standardTile("smoke", "device.alarmState", width: 2, height: 2) {
state("clear", label:"clear", icon:"st.alarm.smoke.clear", backgroundColor:"#ffffff")
state("smoke", label:"SMOKE", icon:"st.alarm.smoke.smoke", backgroundColor:"#e86d13")
state("tamper", label:"tamper", icon:"st.alarm.smoke.smoke", backgroundColor:"#e86d13")
state("lowbat", label:"lowbat", icon:"st.alarm.smoke.smoke", backgroundColor:"#e86d13")
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'${currentValue}% battery', unit:""
main "smoke"
details(["smoke", "battery"])
// parse events into attributes
log.debug "Smoke Detector description: $description"
def results = []
if (description.startsWith("Err")) {
results << createEvent(descriptionText:description, displayed:true)
} else {
def cmd = zwave.parse(description, [0x71: 2, 0x84: 2, 0x80: 1])
if (cmd) {
//log.debug "Smoke Detector CMD: $cmd"
//log.debug "Smoke Detector CMD properties: ${cmd.getProperties()}"
zwaveEvent(cmd, results)
log.debug "\"$description\" parsed to ${results.inspect()}"
return results
def createSmokeEvents(name, results) {
if (name == "smoke") {
// these are displayed:false because the composite event is the one we want to see in the app
results << createEvent(name: "smoke", value: "detected", descriptionText: "$device.displayName smoke was detected!", displayed: false)
// This composite event is used for updating the tile
results << createEvent(name: "alarmState", value: name, descriptionText: text)
} else if (name == "clear") {
results << createEvent(name: "smoke", value: "clear", descriptionText: "$device.displayName smoke is clear!", displayed: false)
} else if (name == "tamper"){
results << createEvent(name: "smoke", value: "tamper", descriptionText: "$device.displayName has been tampered with!", displayed: false)
results << createEvent(name: "deviceAlert",value: name, descriptionText:"$device.displayName has been tampered with!")
} else if (name == "lowbat"){
results << createEvent(name: "smoke", value: "lowbat", descriptionText: "$device.displayName has been tampered with!", displayed: false)
results << createEvent(name: "deviceAlert",value: name,descriptionText:"$device.displayName has a low battery!")
def zwaveEvent(physicalgraph.zwave.commands.alarmv2.AlarmReport cmd, results) {
if (cmd.zwaveAlarmEvent == 2){
createSmokeEvents(cmd.alarmLevel ? "smoke" : "clear", results)
} else if (cmd.zwaveAlarmEvent == 254){
createSmokeEvents("tamper", results)
} else {
createSmokeEvents("lowbat", results)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd, results)
createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)
def userWake = getUserWakeUp(userWakeUpInterval)
// Only ask for battery if we haven't had a BatteryReport in a while
if (!state.lastbatt || (new Date().time) - state.lastbatt > 50*60*1000) {
results << response(zwave.batteryV1.batteryGet())
results << response("delay 1500") // leave time for device to respond to batteryGet
// If user has changed userWakeUpInterval, send the new interval to the device
if (state.wakeUpInterval != userWake){
state.wakeUpInterval = userWake
log.debug "Setting New WakeUp Interval to: " + state.wakeUpInterval
results << response(zwave.wakeUpV2.wakeUpIntervalSet(seconds:state.wakeUpInterval, nodeid:zwaveHubNodeId))
results << response("delay 200")
results << response(zwave.wakeUpV2.wakeUpIntervalGet())
results << new physicalgraph.device.HubAction(zwave.wakeUpV2.wakeUpNoMoreInformation().format())
results << createEvent(descriptionText: "$device.displayName woke up", isStateChange: false)
results << createEvent(name: "deviceAlert",value:"clear",descriptionText:"No more alerts are found!")
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd, results) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "$device.displayName battery is low!"
} else {
map.value = cmd.batteryLevel
results << createEvent(name: "deviceAlert",value:"clear",descriptionText:"Reported Battery Level: $cmd.batteryLevel")
state.lastbatt = new Date().time
results << createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpIntervalCapabilitiesReport cmd, results) {
def map = [ name: "defaultWakeUpInterval", unit: "seconds" ]
map.value = cmd.defaultWakeUpIntervalSeconds
map.displayed = false
state.defaultWakeUpInterval = cmd.defaultWakeUpIntervalSeconds
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpIntervalReport cmd, results) {
def map = [ name: "reportedWakeUpInterval", unit: "seconds" ]
map.value = cmd.seconds
def zwaveEvent(physicalgraph.zwave.Command cmd, results) {
def event = [ displayed: false ]
event.linkText = device.label ?: device.name
event.descriptionText = "$event.linkText: $cmd"
results << createEvent(event)
private getUserWakeUp(userWake) {
if (!userWake) { userWake = '3600' } // set default 1 hr if no user preference
// make sure user setting is within valid range for device
if (userWake.toInteger() < 60) { userWake = '600' } // 10 minutes - Mininum
if (userWake.toInteger() > 604800) { userWake = '604800' } // 1 week - Maximum
return userWake.toInteger()
